Old 12-12-2012, 02:12 PM
tcrouch0325 tcrouch0325 is offline
Mein Auto: 745i
E65 audio system wiring
I need help figuring out where a wire goes. I bought the car used and the FM, AM, and WB are not working, just static. I replaced the antenna tuner and it did not correct the problem. I disassembled the driver side trunk panels and located the antenna wire from the tuner and it is unplugged. The wire is tied together with a second wire going into the Bluetooth module. The Bluetooth may have been added later, i'm not sure. I have attached photos of my findings. If someone can send me a photo of theirs or tell me here the wire goes. It will not properly fit in the Bluetooth module I have already tried.
ID:	353002   Click image for larger version
ID:	353004   Click image for larger version
ID:	353005   Click image for larger version
Old 12-12-2012, 10:13 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Are you talking about the 2 antennas in pic 4?
Old 12-12-2012, 10:32 PM
Mein Auto: 745i
yes the two colored antenna's in photo 3. (I removed one photo i uploaded by accident)
Old 12-12-2012, 10:40 PM
Mein Auto: 745i
The white connector with the purple color is the same color as the one coming off my antenna tuner. I have not run an ohms test to see if it actually the wire. The other antenna has a right angle connector on it and is colored pink. when it is plugged in, the wire actually crosses over the second connector on the unit.
Old 12-12-2012, 10:47 PM
Ill look at mine and get back to you in a little bit
Old 12-12-2012, 10:58 PM
Sorry its raining outside. But those should theoretically plug into that unit. Just taking a guess though
Old 12-12-2012, 11:00 PM
Mein Auto: 745i
Thank you
Old 12-13-2012, 12:11 AM
Mein Auto: 745i
The one will not plug into the unit correctly. If you would check yours tomorrow, it would be a great help.
Old 12-13-2012, 01:44 PM
Mein Auto: 745i
I just traced the wire and that is not the one I am looking for. Thanks
audio system, audio wire install
