Rear alignment? - Bimmerfest - BMW Forums
Old 12-04-2012, 09:43 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Rear alignment?
Hey guys I am replacing my thrust rods on thursday with Meyle HD's because they are starting to wear a little.. anyway, I noticed once I put the car on the lift that lifts from the tires that the rear drivers side tire looks like it's at a bigger angle then normal.. Would that be camber right? So basically the top of the tire is going in.. is this an alignment or a bad suspension component?
Thanks!
Old 12-04-2012, 10:11 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
As the car gets raised so that the tires will eventually be lifted off the ground, the rear camber also adjust.
Old 12-05-2012, 12:44 AM
Mein Auto: Nothing
Huh? I'm talking about a drive on lift.. tires are never leaving the ground, suspension is fully loaded.. basically it's a lift with two big ramps.. drive up onto it and lifts whole thing.. we have two lifts that lift car by body and drops suspension too, but this particular lift is not mine.
Old 12-05-2012, 03:14 AM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
If it has that butterfly look /---\ then you have negative camber and can bet adjusted with alignment.
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 12-05-2012, 07:27 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
These cars have quite a bit of negative camber from the factory. You will see the inner edge of the tires wear out faster than the rest of the tire. Have BMW or a INDY align the car to minimize the negative camber. They will take it to around -1.0. Not everyone can align these cars. There is a specific method called for by BMW which actually loads the car at certain points with weight before aligning.
Old 12-13-2012, 06:50 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
I was in the tire shop yesterday they did an inspect on my rear tires, found the inner edge wearing a little. At the time I was getting the lowering springs installed, they mentioned I might need a camber kit, after seeing the wear and the machine showing the right/rear out of spec I figured might as well address this now., They ordered a camber kit should be here in a couple of weeks. They said the car is probably "dog toeing" if I heard it right...,,
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 12-13-2012, 08:34 AM
Mein Auto: 745
I just had my car aligned and it's lowered as well... The alignment tech was able to get the alignment and camber within specs without a camber kit
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 12-13-2012, 08:57 AM
I don't know if I should try another shop, I much rather spend the money on some other mods...
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 12-13-2012, 09:34 PM
Expo BMW's Avatar
Expo BMW Expo BMW is offline
Local Enthusiast
Mein Auto: E65,P71 Police Intercept.
Turn the tires inside out THEN switch them from drivers side to passenger. This is how I rotate my rear tires which helps them wear evenly.
. 360infiniteusa Angel Eyes . H&R Springs . mObridge AUX Integration .
Old 12-14-2012, 12:32 AM
Mein Auto: 745
I believe that you should because I they were able to do mine they should be able to do yours as well
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
