7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
I have a horrible oil leak that just sprouted about 2 weeks ago. Approx 1 month ago i replaces the vcg's and timing cover gaskets, and i verified these arent leaking. The alternator bracket gasket is next, but with the amount of oil under my car and in the driveway, i dont think its the only thing leaking. Any suggestions what else could be?
I just fixed a bad leak I had ... It was the o ring seal on the oil filter housing .. You might want to check that as well
BMW 7 Honda S2000 Nissan 300zx TT SuperDuty F350 Suzuki GSXR 1000 |
I had a leak from an oil sensor on the passenger side, it was leaking where the plug goes in so the cover of the plug made it harder to see where it was coming from
I replaced the oil filter and gasket when i did the other gaskets, but i will double check..Thanks!
Ill look into that, Thanks!
If leak is on passenger side check seals on vacuum pump also.
Not trying to hijack but coincidentally i got a bad leak on the passenger side that developed recently and been having a hard time figuring it out, oil pressure switch is it i should check? and i will check the vacuum pump also, definitely not this bad from the VCG i added 2 quarts 1 week ago and had to add again :/
also its worse when the car runs then its parked not as bad when the car is sitting for awhile
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 11-02-2012 at 08:42 PM. |
Just had my mechanic do some work on my car on Thursday. After the work was done I did a visual and my vacuum pump is leaking. I noticed my oil level being a little low, so I knew something was up. he said it's a $600.00 part. He's checking to see if he can get a deal. He works out of his house on the side. It's easy to see if the pump is leaking. Take the center cover off and look down to your left (engine right). You should see traces of oil residue on the lower pan. Pump also shows oil residue.
Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
Thanks wjjklj. I'll give that a look. Everything is expensive on these cars so when you can save money, it's a good thing.
I had that too. It was the oil cooler adapter plate. If your car doesn't have an external oil cooler, they put a plate, with an O ring seal. That starts to leak. It's a good size leak too. The problem is it's behind the Alternator and motor mount on left side. My left side is completely dry now that it's fixed.
Would that be the same as the "alternator mounting bracket gasket"? The little t-shaped gasket?
That I'm not sure of. My mechanic did the work. It was more then one seal or gasket. I think the major cost is labor. Hard to get to.
Check the oil pan seal is a common problem
![]() 2001 X5 3.0i 200k miles & counting...( SOLD) Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights 06 750Li with 19k miles. Bone stock. |
And OT, could you post a pic of the rear of your car? I see your light are blacked out and I want to know how I would feel about doing the same
It's hard to tell right now, there is a lot of oil runoff from the alternator accumulating on the oil pan
Don't like this picture because of reflections. I'll take some others.
oil leak
check your oil pan gasket as well....that was the culprit on my 760li...one thing though the gasket is built into the oil pan.....yep..!
wjjklj,
In this post I talked about my vacuum pump leaking. You stated it could be resealed. Do you know where I could get the seals from? Thanks.
i replaced mine recently:
http://www.bmpdesign.com/product-exe...earch_model/15
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
Thanks 745iguy. I'll show that to my mechanic. Should work.
I answered your PM but yes try BMPDesign. Kit costs about $28.00 including shipping.
Pictures:
TIS included
