E34 (1989 - 1995)
Old 12-12-2012, 04:44 PM
luckyLuciano luckyLuciano is offline
~Luciano~
Mein Auto: 1994 525i
Replacing a head gasket, what else do i need to do?
I have a 1994 525i M50 with vanos.
ill be buying Head gasket set
Bolts
Valve cover Rubber seal and washer
what else would i need?
Old 12-12-2012, 04:53 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
that should be fine, depends on what else you'll need to replace when you're in there. So far thats a decent list. When you have the head off, send it to a machinist to have him measure it and make sure its flat and crackless. while it's gone see if theres other parts you wanna replace...
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 12-14-2012, 09:30 PM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
That's why I hate working on the BMW. Everything has to be ordered or it will cost an arm and leg.
I seem to recall the valve cover gasket used flange nuts. How about a new coolant drain plug? Don't forget the coolant.
Are you replacing some of the hoses or clamps? Have fun let us know how it ends.
Old 12-15-2012, 05:42 PM
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette, 530i
Don't know if you've already started but my post may help. Pay special attention to the cam removal as they are hollow and don't unbolt like traditional cams. Not following the correct procedure will result in breaking them.
http://www.bimmerfest.com/forums/sho...624&highlight=
Old 12-17-2012, 07:39 AM
Monsignor's Avatar
Mein Auto: Sig
^1,000,000
cams are a toughie in this regard. Ive gotten so used to taking them out and putting them back its like a second nature for me, forgot abou that. this is the article i used and it was awesome.
BMW Camshaft Removal and Installation
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 12-17-2012, 08:17 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
this is important, assuming you are replacing it because the car over heated, and not just for the hell of it. the aluminium heads on these engines warp VERY easily
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
