E90/E91/E92/E93 (2006 - 2013)
Old 12-13-2012, 07:27 AM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
RFT vs Non-RFT Air Pressure Question
The Basic question I want to ask is:
Should PSI be higher on NON RFT's compared to similar spec RFT's?
I got 18" staggered wheels on my e90 and I recently put on Michelin Pilot Super Sports.
User manual states I should run 36psi front/42psi back for extra load. I ran this on my old NITTO NON RFT Tires (Softer tire from what I experienced) and the fronts had shoulders wear off noting that they were under inflated.
I wonder 36/42 is for RFT's and if I should run higher for these NON RFT Michelin PSS's.
Old 12-13-2012, 07:40 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Street, naw.
I get best results at BMW owner's manual recommended psi.
Old 12-13-2012, 08:42 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Mein Auto: 2009 335i xDrive coupe
+1. What CWB says for same size tires.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 12-13-2012, 09:02 AM
tturedraider's Avatar
Freedom isn't free!!
What they said. The type of tire does not affect the recommended air pressure. btw - there's virtually no way that 36/42 is going to result in an under inflated situation.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 12-13-2012, 09:21 AM
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Mein Auto: 2008 335Ci
I actually DROPPED my pressure by 2 PSI front and rear. I noticed my Michies were not using the outsides of the tread.
Softer ride with no noticable change in handling.
No matter how fast I go, there's always someone slower in front of me.
JB4 PNP .... Love at every stomp on the go pedal!
Old 12-13-2012, 08:24 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Short answer: RFs and non-RF tire pressures are guided by the same tire/load/pressure standards according to U.S. standards: The U.S. Tire and Rim Association. There is NO difference. Size-for-size, RFs and non-RFs carry the same load and have the same PSI requirements.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 12-13-2012, 10:17 PM
Mein Auto: 08 E90
That clears things up! Thank you.
