E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Ok, so I have a problem...I bought a car charger for my phone, only to find out it can't snuggly fit into the cigarette lighter. It is hitting the piece which makes contact with the lighter itself. Making it so the port and no firmly fit, so it is wobbly. I've tried googling around, but couldn't find a similar thread or solution, perhaps I was just searching incorrect terms?
Any insight would be much appreciated. Thanks! |
They all do that. Not sure why but I have the same issue. Always wobbly no matter which charger I use.
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
Well, new cig lighters are "power ports"...i believe they just have a small plastic spacer on the bottom, so you couldn't use a cigarette lighter in them if you wanted too, where as this one has the large metal piece to make contact. That piece is the reason they wobble...was wondering if there might be an easy way to fix it...with out tearing everything a part to put in a power port.
Not really sure what you're getting at here. The "lighter itself", as I see it, is the actual heating element which you remove when plugging things into the socket. Is your phone adapter too big or too small for the socket? Regardless, I'd probably get a different phone charger rather than messing with your cigarette lighter socket. If it doesn't fit snugly into the socket, you can very slightly raise the metal contact tab a little bit so it has more "spring action". Just be sure to either use something plastic to bend it, or disconnect the battery while doing it. I suppose you could use a screwdriver, but just don't touch anything but the plastic handle.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 12-13-2012 at 08:58 AM. |
You miss what I'm getting at, if you look inside the cig port, there is a large metal piece which makes contact with the actual lighter. Power ports do not have this piece. If this charger does not fit, I don't believe any of them will...the new ones at least. Since they are a universal design. The one in question is actually a compact design. The BMW port simply isn't deep enough for full insertion due to the metal contact piece in the bottom.
Hmmm... Interesting. The charger for my Garmin navigation fits fine.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
I've had that issue with some Verizon chargers, but I actually think it's due to the cheap quality and manufacturing. Every other device I've ever plugged in works fine in those cars and they run the gamut of inverters to expansions to detectors and more, from old to new.
The problem isn't the bottom of the port, it's that the charger is too narrow. Open it and bend the side prongs to bow out more. Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
You can see, the width appears to be the same, i'll double check to be sure; but it's the depth that is different. It hits the metal in the bottom. I'll have to see if other compact ones fit, as anything taller would likely get in the way of shifting.
That's not the issue though. Your charger is taller than the lighter piece, which means the bottom is making contact. The side contacts are low on the charger, so were they the right width they would be making secure contact with the walls and you'd have a complete circuit.
It's not too tall - It could be 8" tall and as long as it had the contact on the bottom and contact on the sides it would fit and work. The issue is yours is too narrow so the sides don't make sufficient contact to get a good circuit and stay in place. Sent from my LG Revolution 4G using BimmerApp
True, but I was hoping to kill two birds with one stone. As this is designed for a flush fit. I'll check the width later. and bend em out if needed. But sitll, would like to be able to fit a flush mount in.
there is no way to do what your describing.
yes i understand what you want. but there is not a economical way to do it
nothing.
Oh bother, guess I'll have to rip it out and put in a better port then, or just put in a usb one altogether. thanks though.
Wouldn't it be easier to just get a better charger?
Yes, or even just to open it and bend the side contacts.
You're assuming another flush mount charger would fit; and I haven't seen a shorter one than this. So ideally yes, I could just throw a different charger in there, but I'd have to find one that is much shorter.
Though I may just go an alternative route and put in a powered female usb into the console, unless I can find a radio that puts out ample power (2+ amps) to the usb port. |
Alright.... what your trying to say that you are not getting across is that he wants the hole for the cigarette lighter to be deeper.
Say from the top of the hole to the bottom is 1.5 inches. his flushmount thingie is 1 3/4 inches tall. so he wants to deepen the port so it would again sit flush.
nothing.
If he's so infatuated with having a hellaxflush charger, I think his other idea is best. Leave the port alone so its available if you need it for something non-usb and just install a USB port somewhere subtle like in the row of blanks next to the lighter. In fact, I love that idea. But the port would be best left alone
Thanks for the replies guys. Edit: Oh, I checked. Bending the prongs would do nothing for my problem, as it makes contact perfectly fine. But w/o sitting flush, it can wiggle about. Oh, and I am away I need to clean the interior, that is also on my list of to dos lol. |
If you seek perfection, why not just go the distance and hardwire the USB setup?
run the cord to the glovebox an go from there.
you shouldnt need your phone while your driving anyways right...?
nothing.
Ideally, I'll get rid of the head unit altogether and just have my phone in its location. Though that is way on the back burner. |
Ideally you would convert the sunglass holder to a wireless charging dock and stream everything to your head unit via Bluetooth.
#25
| Bookmarks |
| Tags |
| charger, cigarette, deeper, port, power |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
