Fuse 6 88 528E - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 12-13-2012, 11:57 AM
jeffm28374 jeffm28374 is offline
Mein Auto: '88 BMW 528E
Fuse 6 88 528E
I have an '88 528 E that keeps blowing fuse 6. Dome lights, tach, glove box light, after market radio. Could it be after market radio? If so what is the best thing to do? many thanks!
Old 12-14-2012, 11:58 PM
kyE28 kyE28 is offline
Mein Auto: 87 528e
check the wiring
check that the wire for the dimmer switch is taped up, in my 528e i left it alone and untaped and it shorted out on the back of the radio and would blow the exact same fuse and since i taped it up it hasnt been a problem!
Old 12-23-2012, 10:17 PM
catso's Avatar
catso catso is offline
catso
I'd suspect the SI board. Go to Mye28.com and research it there. Lots of info on replacing the NiCad battery that usually leaks and causes these problems.
![/I][/FONT]
HTML code is Off
