The X5 SAV Forum
Old 12-21-2012, 03:32 AM
alphadog777 alphadog777 is offline
Mein Auto: X5 4.4i sport
Question adjustable ride height switch does nothing, no blinking, no suspension inact.
I just recently purchased a 2003 X5 4.4i and i noticed that the switch to adjust the ride height does nothing, it shows a led in the normal setting but thats it. if u press it nothing happens, no blinking, nothing. BUT the car sits totally level and rides perfectly fine (no inact message). ive heard the pump kick on when i started it just last night and then turn off after about 30 seconds. im getting no indications that anything is wrong with the system, except that it dosent go up or down? all doors shut, car on, in park, am i doing something wrong?
Old 12-21-2012, 10:01 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
It's possible the PO had it removed (Replaced with springs) and disabled. It is a popular modification to increase reliability.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-21-2012, 01:19 PM
yea i can see that being a possibility, maybe its not the pump im hearing? which is fine by me, less to worry about. Ill have to check underneath, what am i looking for? I did notice that my "problems" weren't really consistent with others, most people at the very least get a blinking light, mine literally does nothing. I haven't once noticed that the wheel gap has changed, and ive been looking.
Old 12-21-2012, 02:01 PM
i just took a look at my carfax and i dont see anything reported from the dealer about changing suspension. has anyone heard of the X5 behaving like mine?
Old 12-21-2012, 02:10 PM
petriej's Avatar
I'm not 100% sure what would be a sure fire way to notice, but you could check the rear springs. If the air system was removed there won't be a boxy air cushion, but instead just a spring.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-21-2012, 02:26 PM
ok so im assuming its a McPherson setup, and the spring is replaced with airbags. lamens terms obviously. if thats what your telling me i can definitely spot that haha, when the wife gets home with it ill keep you posted on what i see
Old 12-21-2012, 02:35 PM
petriej's Avatar
Yes, I think so. Not 100% on that. I can run out and check if you like. My X5 has operable air suspension.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-21-2012, 02:40 PM
petriej's Avatar
Yep, looks like a gas shock and an airbag system on the trailing arm. (Or control arm, I always mix those terms up)
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-21-2012, 02:49 PM
sweet, with any luck they changed it out to springs (crosses fingers) although i would love to feel like a badass with my x5 lowered down. im gunning for it being removed haha
Old 12-21-2012, 03:04 PM
just to clarify, im not talking about the auto levling suspension system. im talking about the adjustable ride height which is an option and not standard. from what i understand they are different.
Old 12-21-2012, 03:12 PM
petriej's Avatar
Hmm, I thought they used the same bags. Now I'm not sure.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-21-2012, 03:46 PM
they very well might, i dont know squat about this car right now. im working on that though
Old 12-22-2012, 10:30 PM
UPDATE: so i figured out the issue, turns out it does have the system still. The reason it doesn't work is because the dealer locked it in the middle position, after the suspension had an overhaul before it went out onto the lot i got it from. they recommended that i didn't get it unlocked to keep the wear and tear on the system to a minimum. im still on the fence about what to do with it.
adjustable, air, ride height, self leveling, suspension
