Is The 2014 Nav Update Worth Doing? - Page 7 - Bimmerfest - BMW Forums
Closed Thread
Old 12-24-2012, 04:27 PM
fplanner2000 fplanner2000 is offline
Fplanner2000
Mein Auto: 2011 550ix Mpkge,etc; RRv
I have no "RAR part 1" - where is this?
_________________________________________________
550ix, Dark Graphite Metallic II, M-package, Dinan Stage 2, 20" wheels, conven pkge, cold weather pkge, Prem Pkge 2, Paddle Shifters, vent seat pkge, sport transm pkge, fold-dn rear seat, etc. Black Dakota Leather, Light Wood trim
Old 12-24-2012, 04:33 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by fplanner2000 View Post
I know I've got to be making this much tougher than it is. I downloaded all 23 parts. What is it I am opening with Winrar? All I have is the 23 files. WHere do the config file and pkgdb folders live? How does the torrent file figure into all this, if at all?
I've already got my code, but can't figure out how exactly to access the files to load onto my usb.
You use WinRAR to open "v.2013_NA_PREMIUM_CIC_USB.part01.rar", which will actually open all 23 parts for you behind the scene, and then you will see inside the archive a file named "BMW_NAV_2013_NA_PREMIUM_USB.img". Drag this file to your desktop to extract it from the archive.
Now open "BMW_NAV_2013_NA_PREMIUM_USB.img" on your desktop with 7-Zip and you will see the config file and pkgdb folder. Drag these to your desktop to extract them from the archive,
Lastly, copy the config file and pkgdb folder to the root directory of a Fat32 formated drive. If you are unsure about your drive format, open Windows Explorer, Right Click on the Drive and select Properties, and on the General Tab, look at the File System. It should say Fat32. If it says something else like NTFS, you will need to reformat it to Fat32.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
  #153
Old 12-24-2012, 04:36 PM
You don't have this file?
Old 12-24-2012, 04:37 PM
Fplanner2000
Thanks - I knew I was making it too complicated.
  #155
Old 12-24-2012, 04:41 PM
GIANITALIAN GIANITALIAN is offline
Mein Auto: 2012 535I M SPORT
ID:	354506 this is the last step ? take a long time. to compress from WinRAR TO 7 ZIP.
2012 535i M Sport, Space Silver Metallic, Black Leather and Light Wood Trim. Major options are M Sport package, cold weather package, sport automatic transmission, active roll stabilization, premium sound, and view cameras.
  #156
GroveTuckey GroveTuckey is offline
Mein Auto: 2009 328xi
Originally Posted by shawnsheridan View Post
I show it is 16.2 Gb Packed inside the RAR file, and 31.4 Gb in actual size when extracted:
Attachment 354487
Maybe with the Mac OS File System, it reports differently.
Well I am getting a 21 gig file from the windows side also. No errors in winrar. I was trying to look at GIANITALIAN to see if I could tell the size of the file he had but the pic was not close enough.
Name:	Screen Shot 2012-12-24 at 6.34.58 PM.png
  #157
Old 12-24-2012, 04:44 PM
Sorry the last pick was clear. But was he 7zing the file? Up it seems like he was....
I think he should be using 7z to get the files from the .img file.
If someone has the files on a usb drive can they look to see what the size is on the drive?
I am just trying to make sure I don't have messed up files as I am not able to upgrade my system the USB port.
Thanks in advance!
  #158
Old 12-24-2012, 04:47 PM
Originally Posted by GIANITALIAN View Post
Attachment 354506 this is the last step ? take a long time. to compress from WinRAR TO 7 ZIP.
No wonder. That picture shows you are compressing it. Compressing an already compressed image file will take a damn long time, not to mention won't do anything.
You need to be extracting it. Just open the .img file in 7-Zip and drag the file and folder to your desktop to extract it. That is it.
  #159
Old 12-24-2012, 05:00 PM
PittX52011 PittX52011 is offline
Mein Auto: 2011 X5, 2013 550 xi
The final file in my USB is a folder name pkgdb and it is 21.2GB. Is that the right one. I wanted to check with you before I put this in my glove box.
  #160
Old 12-24-2012, 05:04 PM
It also has a file named config.nfm which is 1kb
  #161
ok . i did it wrong. this way i think it is ?Click image for larger version
  #162
Old 12-24-2012, 05:13 PM
ok . i did it wrong. this way i think it is ?Attachment 354508
Yes. Now you are Extracting.
  #163
Old 12-24-2012, 05:16 PM
This is correct. The .img file is a USB Image file, so it is a mirror image of the entire BMW Map Thumb drive, byte-for-byte, so it is a full 32 Gb.
The actual content, the file and folder is actually only 21 Gb.
  #164
Old 12-24-2012, 05:22 PM
Yes I am getting exactly what are you getting. In the upper right corner of your extraction screen you see total size which is 21764 MB, however GIANTALIAN's extraction screen total size in the upper right corner is around 29000MB. Also his file says PREMIUM_CIC_USB, while yours and mine only says PREMIUM_USB.
I don't what different he is doing. GIANTALIAN can you give any suggestions.
  #165
Old 12-24-2012, 05:23 PM
ImSW1 ImSW1 is offline
Mein Auto: F10
Looks like you're extracting the file. As Shawn has stated it should result in a folder (pkgdb - 25 folders and 12 separate files) and then a separate file (config.nfm). The folder logs at 21.2 GB and the config.nfm logs at 237 bytes. If your setup looks like this it will complete the update fine.
As a note. You don't have to do the update in a complete session. I shut down my vehicle 4 times during the update. It restarted where it left off when I started the vehicle again.
Of course, thanks to Shawn for managing the files for this. If it was open we'd probably lose the upload in a few days. It takes a significant amount of time to make the files that Shawn does available and still he doesn't ask for anything in return. Seems like a pretty good deal for us.
Sean
  #166
Old 12-24-2012, 05:35 PM
somethink stange happend , i have to doit again and now say copying, but same size and NA PREMIUM USB IMG
  #167
Old 12-24-2012, 05:36 PM
  #168
Old 12-24-2012, 05:42 PM
I think he just got confused and messed the files up some. He will need to start over.
So if I am not able to upgrade via usb would a dealer make it to where I could. I hate to pay them but if it could save me money in the following years I may have them do it. I think if I can't upgrade my maps with the current way they are providing them they should update my software under warranty.
Thank!
  #169
Old 12-24-2012, 05:45 PM
finally this came out. Click image for larger version
i guess is copy this2 files to the thump drive?
  #170
Old 12-24-2012, 05:47 PM
finally this came out. Attachment 354514
Yes copy them to a 32 gig FAT32 formatted thumb drive
  #171
Old 12-24-2012, 05:50 PM
copying to thump drive.Click image for larger version
  #172
Old 12-24-2012, 05:57 PM
JEG23 JEG23 is offline
Mein Auto: 550i
Honestly, I think that when something as simple has extracting a file is so difficult, then you should have the dealer take care of you.
Shawn is a treasure to the coding community. We should value his time.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
  #173
Old 12-24-2012, 06:37 PM
JEG23
I agree Shawn is very helpful.
I assume that comment was not directed to me, but if I take my car to the dealer and they can't update with the USB will they upgrade the CIC software or what have you for no charge?
  #174
Old 12-24-2012, 06:46 PM
It worked. My X5 updated the map data. Took about 40 minutes. Thanks Shawn.
  #175
Old 12-24-2012, 06:53 PM
Mein Auto: F10
Highly doubtful they'll do the software upgrade for free since the update is something you've requested (Navigation update necessitates a software update). The dealer needs to be paid by someone (owner or BMW) for the labor costs they incur.
I don't know anything about the earlier 3 series cars, but I'll ask my dealer since my car is having a software update done on Wednesday.
Sean
Closed Thread
