E36 (1991 - 1999)
Old 12-14-2012, 06:46 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Seriously, What The Hell Is This Part?
I confirmed the charcoal canister is in the trunk as goes the common knowledge.
So, what is this thing? I can't find it ANYWHERE online and there's conveniently no part number for it on Real OEM. The best part is that it doesn't even have a label on the diagram! It's the bottom right part, the canister looking device. http://realoem.com/bmw/showparts.do?...72&hg=13&fg=15
If anyone can get me a part number and official name to search for it that would be great. Tried googling some of the p/ns in the diagram and none appeared to be it.
Sent from my Galaxy Tab using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-14-2012, 06:59 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
I am 99.99% sure that is the charcoal canister...
Who or what told you it's in the trunk?
Instagram | @randytheus
Old 12-14-2012, 07:04 PM
I Am The Machine
Find me a link to the part for sale please.
// Chad //
You're a derbanana
Old 12-14-2012, 07:05 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
I'll take the .01% to make at an even 100
http://www.bavauto.com/fland.asp?part=16%2013%201%20181%20217&utm_medium=feed&utm_campaign=googlebase&utm_source=16%2013%201%20181%20217&gclid=CKu1mKW3m7QCFeGDQgodIn8AvQ
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-14-2012, 07:11 PM
Gooby's Avatar
Mein Auto: 1995 M3
Boom...
P/N: 16131180886
http://www.ecstuning.com/Search/16131180886/ES36983/
ps - you should just bypass it completely...because racecar...
Old 12-14-2012, 07:13 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
I believe it's your charcoal canister. http://parts.bmwofsouthatlanta.com/p...131180886.html
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-14-2012, 07:17 PM
dc_wright's Avatar
That's not the charcoal canister in the trunk that's the evap system test pump. I forget what year it was mandated, but evap systems after a certain date have to be self verifying. That required the addition of some valves and a pump to periodically pressure the fuel storage and evap control system to check for leaks. This is why you get a CEL if you run the engine with the gas cap loose or missing.
Old 12-14-2012, 07:26 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeah, i thought the charcoal canister was inthe trunk as i saw all sorts of poly tubes and solenoid valves...didn't take the cover off, though, as i was putting various pieces and parts in the trunk oof the parts car.
that being said, all obd2 cars are supposed to be self checking on the evap system. most use manifold vacuum to test, but this thing looks like bmw used a motor to supply vacuum??
never had to perform an evap service to the bmw's is all...lots of others, but no mercedes or bmw's...
could always tell when people would go to a new 'chain' gas station as a rash of loose gas caps would be dropping in...po440....all day....
(nj is a full service state, btw...)
df
Old 12-14-2012, 07:52 PM
dc_wright's Avatar
df
Yes they did and now almost everyone does because the standard has changed again the evap systems get tested periodically even when the engine is off. On the Corolla we had it seemed like it tested about once an hour.
Old 12-17-2012, 10:34 AM
I Am The Machine
Originally Posted by Gooby View Post
Boom...
P/N: 16131180886
That's an OBDI part only brah......
It's called "activated charcoal filter" on Real OEM, which is the same name given to the charcoal canister in the trunk on OBDIIs. (pn 16131183509) I really think the trunk one supplants it. I just don't understand why I have lines for it when RealOEM lists that pn as valid through 95 only.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
You're a derbanana
Old 12-17-2012, 11:09 AM
dc_wright's Avatar
This is the junk in the trunk. It's interesting that for the 328 the housing is called out but not the actual filter.....
Old 12-17-2012, 11:17 AM
I Am The Machine
Right, that's in my trunk, which is obdii.
Look even at the link you gave earlier in this thread, that other part is for M50 only but I still have lines and mounts .
// Chad //
You're a derbanana
Old 12-17-2012, 12:04 PM
dc_wright's Avatar
I only had a few minutes previously to do a quick check but it looks like there's some variations depending on the build date. My car is a 12/1995 build and according to the BMW site I've got a charcoal canister there that also has a shutoff valve attached to it (as do 318's and 323's), but 325s don't get the shutoff valve.....
Also looks like 12/1995 was a transition month too.
Old 12-17-2012, 07:37 PM
I Am The Machine
I'm a late 96 build IIRC, anyone able to take a look at a stock emissions system on their M52 and let me know what's up? This makes no sense to me.
// Chad //
You're a derbanana
Old 12-18-2012, 11:27 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I def have this on my 328i. Two tubes connect to it. I hope you find yours!
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-18-2012, 11:38 AM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Chad, catch me up on this... Do you think you're missing the canister under the hood, yet all the part numbers listed for the part you think you're missing are for OBD1 E36s? I'm pretty sure mine does not have anything like that smaller charcoal canister under the hood (and I know for sure it has that weird thing in the spare tire well), but I can take a look for you. Lemme know exactly what/where you want me to look at, and I'll take a peek tonight after work. And for reference, my 328 was built in 02/97, listed as MY98.
1998 BMW 328is
1966 Pontiac GTO
I Am The Machine
Can you see a part number? The one listed earlier is M42/M50 only according to Real OEM. If it's not obvious don't worry about it.
// Chad //
You're a derbanana
Old 12-18-2012, 11:49 AM
petriej's Avatar
It's at the front of the engine just underneath the intake manifold, right? Black w/ gray stripe tube goes into the bottom, and black w/ blue stripe goes into the side (driver's).
Maybe I'm thinking about something else.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-18-2012, 12:04 PM
I Am The Machine
No, it's mounted to the drivers strut tower under the intake hoses.
// Chad //
You're a derbanana
Old 12-18-2012, 04:29 PM
dc_wright's Avatar
Just got home and had a chance to look in my engine compartment. 328iC, build date 12/95 and I do not have that or anything resembling that in my engine compartment, and no dangling hoses either.
Oh, and I was remembering wrong about the pump being in the trunk on E36s. It was the Corolla we had that had the evap pump back there.
Old 12-18-2012, 04:36 PM
I Am The Machine
Ok. We're making progress, thanks for the info Don.
Next question, in the pic below notice 3 things.
-Blue hard plastic pipe with nothing connected to it
-Rubber mounts on strut tower
-Red cap on port on the fuel evap control valve
The blue hard line and mounts are really throwing me off. The valve is expected, it's the one that mounts to the intake mani brackets on a rubber bushing. Should have a hose connected where the red cap is (dismantlers plugged it prior to cleaning) and I'm not quite sure where it should go.
Any ideas.
// Chad //
You're a derbanana
Old 12-18-2012, 07:49 PM
dc_wright's Avatar
I snapped some pics of my setup. These will either clear things up or add to the confusion because I don't think mine looks anything like yours. I did snap a pic of the so called "hose schematic" on the driver strut tower.....
ID:	353780   Click image for larger version
ID:	353781   Click image for larger version
ID:	353782   Click image for larger version
ID:	353783   Click image for larger version
ID:	353785   Click image for larger version
Old 12-18-2012, 07:56 PM
I Am The Machine
You rock man! Thanks. I'll compare when I get home. My schematic looks the same but I don't think it has the vapor liquid separator text and something else.
But, your setup actually looks pretty similar. That valve looks like it was just connected directly to the blue plastic line. Mine is mounted up by the mani but that could be changed for smog purposes. I need to compare a bit more but that's something. Thanks!
// Chad //
You're a derbanana
Old 12-18-2012, 11:51 PM
I Am The Machine
Don, you're a gentleman and a scholar.
Problem solved. The valve does NOT go here as I thought:
It looks like it actually attaches here as Don showed and the horizontal port is clipped to the blue hose:
ID:	353822Click image for larger version
ID:	353823Click image for larger version
// Chad //
You're a derbanana
Old 12-19-2012, 02:45 AM
dc_wright's Avatar
Bingo!
:3
