E34 (1989 - 1995)
Old 12-15-2012, 10:32 AM
Tlaw822 Tlaw822 is offline
Mein Auto: 1991 535i
E34 driver side speaker issue
Ok here is my issue, I have a 91 535i with stock sterio, I'm getting some sound out if my driers side front speaker when faded to the front and balanced to the left however the volume has to be ate almost to max. I replaced the amp with another factory amp with no change. Also tryed disconnecting each of the 3 speakers in the off chance it was a speaker issue without change. All other speakers work just fine. Originally this problem started as the drivers side cutting in and out with bad crackling, that's why I got the new amp but the problem continued untill the cutting in and out stoped and I was left with very low output. Any help would be great! Thanks
Old 12-15-2012, 11:00 AM
e34_spangler's Avatar
e34_spangler e34_spangler is offline
e34 User
Mein Auto: e88 135i
Sounds like a bad connection somewhere
Sent from my SCH-I535 using Bimmer App
Old 12-15-2012, 09:25 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
this^
If it didn't change when you swapped out amps. Then it's a short or exposed wire in the stereo wiring harness. There's a PDF somewhere on it by ADS.
But here's the wiring legend:
Found the link:
http://www.bmwe34.net/E34main/Upgrad...we34_radio.pdf
Old 12-16-2012, 06:59 PM
e34 User
Mein Auto: e88 135i
A loose connection touching something else will make that sound
Old 12-16-2012, 09:38 PM
Cleaned up the legend a bit.Actually found the pdf.
I had reviewed what I put up first and almost went blind.
535i, alpine, e34, speakers, sterio
