Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-15-2012, 02:53 PM
m3e46freak m3e46freak is offline
FREQ
Mein Auto: m3
e46 m3 Maintenance
Hey guys and gals, I just recently did my Belts and pulleys(rollers only needed) and fuel pump/sending unit so if anyone needs guidance I could be of assistance.
Old 03-11-2013, 06:27 AM
07lilredwagon 07lilredwagon is offline
Mein Auto: 07 e91
Could you walk us through the fuel pump procedure
thanks
JP
Old 03-11-2013, 07:44 AM
FREQ
Mein Auto: m3
I could, for an e46...
Old 03-11-2013, 10:59 AM
Mein Auto: 07 e91
I think that would be helpful....I dont see many fuel pump DIYs here...though they are mentioned...not a lot of how to's
JP
Old 03-11-2013, 11:21 AM
FREQ
Mein Auto: m3
Oh man ok where should I put the thread at?
Old 03-29-2013, 03:00 PM
bashvd1 bashvd1 is offline
Mein Auto: bmw E46 318i
Talking E46 run out of gas on half tank
Hi guys I had this problem I run out of gas when my gauge say half tank and my fuel light didn't even came on I did some browsing on the bimmer forums and saw a lot had the same problem well this was the solution replacing the fuel filter by following the diy method it was quite easy under the passenger. Seat by removing some covers I just unscrewed the clamp remove the two hose clamps and replace it with the new one my fuel was very dirty that came out of my old filter I gave it a drive just add a couple litres of gas to monitor and my needle is actually past the quarter tank so I guess problem solve thanks a lot for the info I paid 120 rand south african currency I've also read some guys replaced fuel pumps so if u come across something similiar first replace the fuel filter
