Old 12-15-2012, 04:09 PM
Teacher Blind Teacher Blind is offline
Mein Auto: 2006 BMW Z4 3.0si
Should I be concerned?
Z4 Roadster/E85
I am just now noticing a taping sound at idle. Sounds like a valve train issue. Due for an oil change in 1000 miles. Any thoughts? Do I need to jump on this right away?
Old 12-15-2012, 05:10 PM
jafxdwg jafxdwg is offline
Mein Auto: 2008 Z4 si
I had similar in my 08 3.0si.
My car was still under warranty.
The exhaust lifters were the culprits.
Apparently I got the third revisions of those, as this has been an ongoing condition.
Apparently one of the issues is that while the tap is irritating, even embarrassing, mechanically it isn't a problem.
Old 12-15-2012, 05:34 PM
RufusKing RufusKing is offline
Send a message via MSN to RufusKing
Mein Auto: Z4 3.0i Roadster
Originally Posted by Teacher Blind View Post
Z4 Roadster/E85
This will go away when you change the oil. If it doesnt then lifters are the culprit. I had an E85 and it did the same thing. have you checked to make sure you were full of oil?
This one is called OPey
2009 BMW Z4 sDrive 3.0i
I call her weezey
2006 BMW Z4 3.0i Roadster - Sold and I miss her.
Old 12-15-2012, 05:40 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Had the same issue with my 94 325is. I changed the oil, but I got thicker oil and just like that no lifter tapping at all!
Old 12-17-2012, 10:26 AM
Living Dead Living Dead is offline
ZEDHEAD
Mein Auto: 2015 sDrive35is
My 2006 3.0i roadster has been doing it on and off since I purchased it in 2009 with 39,000 miles on it. Now I have 89,000 on it and it still does it from time to time. I've stopped worrying about it and just turn up the radio.
“Thou art to me a delicious torment.” Ralph Waldo Emerson
Old 12-17-2012, 01:40 PM
Well .. Hydraulic Lifters need to get "pumped up"
with oil..
The "tapping" you hear is the clearance between the lifter, valve and rocker arms etc
while the lifters are being pumped up with oil ...
More viscous oil would assist in holding the hydraulics fully pumped.
As was explained to me ...
BMW's resistance to replacing exhaust lifters is related to the tapping not really being a sign of pending valve train destruction.
Old 12-22-2012, 11:24 AM
Landrovah Landrovah is offline
Mein Auto: '08 3.0si, 6MT, Roadster
My 2008 z4si had that. Was on and off so I took my iPhone and recorded a video of it in my garage. I think there is a service bulletin out for it but may want to ask. Its was the lifters as noted above. I'm not sure that it was too serious but I had them replace them under warranty anyway. In and out in a day.
