E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Clutch
Ok. So my 93 bmw 318is have 89530 on it. Just replaced the clutch at 89460. Before I replaced and after I replaced the clutch I've had the same issue. The clutch engages and disengages quite high. When the clutch engages it engages just a little higher than when it releases(pushing in). What could this be? The disc was fine and didn't need to be replaced.
-CJ
Yea disk was fine. We just got new pilot bearings throw out bearing and pressure plate?
This is what came in the kit.
-CJ
What's in the picture was replaced. maybe the disc was replaced. It to late for me to comprehend myself. Sorry
What you pictured was (l to r) the pressure plate, two pilot bearings (you only need one), two alignment tools (again, you only need one), a throwout bearing, and on the right, a clutch disk.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
They sent two and we used both tools. And yes then we did replace clutch disc
And ideas why it's such a high engagement point?
Possibly you have the wrong throwout bearing. They vary in thickness between M and non-M.
How did you use both alignment tools? You can only put one in there, and should only NEED to use one of the correct size and length.
It's not the m clutch kit. And we used one pilot bearing. We used the one that fit the input shaft. We did it right. I think it might just be something to get used to. This is what happened when we took out the trow out bearing. So I think the way the clutch was when the trow out earring was like this is gonna be something to get used to
As you can see two balls were jamme together and wouldn't move
This is what I was questioning, not about the pilot bearing. I assumed they sent two pilot bearings because there are different-size input shafts.
Correct. They sent two ad we used the one that fit
No we used one tool. Haha sorry my bad
The pilot alignment tools I've used had a stepped pilot bearing portion so it would fit either bearing. One tool fit either setup. Oh, well, you got an extra of each!
And that old throwout bearing?
Nice! Well I applaud LUK clutch for the kit. The exact same clutch was in it too. So it was like taking old one out and getting it cleaned and fixed. Haha but I know the throw out bearing was sketchy
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
