F12 / F13 (2012 - Current)
The future is now! The all new 6 series coupe (F12) and convertible (F13) details are out and dealers are taking orders. Still no word on when the 4 door Gran Coupe will go into production. |
#26
received the kombi today, cant wait to get it programmed
#27
#28
Very cool video.
650i xDrive Coupe (2012), Carbon Black/Black/Gray Poplar, M Sport, Full LEDs, 20" 373M Wheels, ARS, HUD, CWP, Premium Sound, Nappa Dash w/ Contrast Stitching, Ceramic Controls, BMW Apps, PCD http://www.youtube.com/user/Southern6er22 http://southern6er22.blogspot.com/ |
#29
I have an 09, can I retrofit the panel?
2009 750Li 400bhp! Milano/Saddle / Lux seating / camera / prem sound / sports pkg / convenience pkg / rear entertainment / heads-up display / iphone integration / 9.14 ED Dropped in Munich on 9/18, Redelivered in Brunswick, GA on 10/12 by ELEKTRA. Delivered to my home on 11/2.
#30
No, it's for f series only
#31
Yes, you should be able to.
His 2009 750Li is an F01.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#32
What if your 2012 Nav does not support Eco Mode. I have read that your nav unit needs to be built later than June '12 to have Eco Mode. Can the Nav unit be retrofit'd to include the Eco Mode option?
Don BMW 1300 (2x650's) |
#33
Sorry I assume its a 6 series since its a 6 series forum...
#34
We are able to code the 2011 nav unit to have the Eco pro functions, I just can't get the car to engage Eco pro mode.
#35
Andreo,
Here are some pics of the red line between the speed limit and actual speed. I also took some more of the phone list and music list. Sorry about the flash, had no clue it was on. |
#36
6WB Multifunctional Instrument Panel Retrofit
Very cool. And I think I can forgive the glare and off center shot since you were going 87 mph; 2 mph less and it would be unacceptable!
#37
+1
#38
BTW, how you even managed to capture a shot at 87mph remains a wonder. Drive safe. |
#39
We can set a limit where there's a gong if you hit it. I have to turn it off whenever my mom's in the car because she takes it as a sign of imminent death and apocalyptic events.
#40
Here is a good description of what LIM does. http://www.bimmerfest.com/forums/sho...&highlight=lim |
#41
So for example, if your speed is set at 88km/h, you can accelerate until the speed reaches 88 km/h and the car maintains speed at 88 km/h, even when the pedal is still depressed. If you depress the pedal a little more or kick it down, the speed ceiling will temporarily be disabled and you can speed up. This is necessary in case of emergencies. I am hoping that the 6WB display will show the actual ceiling speed on the speedometer ring instead of a nondescript green dot which is quite hard to spot especially when you are traveling at "optimum" ticket-free speeds.
#43
Similarly, what does 6WB show for Cruise Control setting on outside dial?
Does it just have a mark (dot) or the actual Speed Setting?
#44
+1. Cruise control shows as an orange dot in the standard instrument cluster.
There are some green speed markings in the OP's pics. I wonder whether those are speed limits from Cruise Control or LIM. Any opinions? Last edited by andreo; 05-05-2013 at 09:29 AM. |
#45
they look exact same as my original instrument cluster, little orange arrow when you set the speed, it turns green when you engage it.
#46
Then what is the 72 showing on the dial in both Orange and Green here:
http://imageshack.us/a/img515/127/image2vz.jpg http://imageshack.us/a/img801/3839/image3mv.jpg Is that not the actual Cruise Control Speed? Maybe only in Sport Mode it appears, and in Comfort or EcoPro, you get only the dial indicator without the actual Speed setting?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 05-05-2013 at 09:49 AM. |
#47
I haven't tested cruise control, I will go out for a ride now and let you know.
#48
Ok so when in comfort mode, it's a green arrow no speed. It shows the cruise control speed at the bottom (where the green car is in the pic) for a few seconds but then disappears. Although in all modes the cruise control speed is on the HUD.
In sport mode the arrow is still there but also shows the speed, again the speed is also on the HUD. I will try to code LIM today and test out how it shows it. |
#49
#50
I will look through the DKOMBI module to see if I can find anything that would keep the speed on in all modes. Although if you have HUD, then it really doesn't matter.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
