F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#26
Confirming my assertion, I just exported mine, and I too show F001-12-07-520:
?xml version="1.0" encoding="utf-8"? bmwExportData signedContent header date>2012-12-16T20:44:27 version>1 username>SHAWN vin>CXXXXXX i-step>F001-12-07-520 So, all 3 of us have the exact same I-Level...except my car was programmed on 10/8 with ISTA/P 2.47.7, I-Level F010-12-07-533, as shown on the ISTA/P Final Report: And when I read my actual VCM in E-Sys, it also shows I-Level F010-12-07-533: As I said, the Profile Export is not accurate.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 12-16-2012 at 07:22 PM. |
#28
If you are referring to your profile, that is because it is in .xml, which has HTML tags in it that the forum thinks is BB Code. Remove all the tags (e.g. "header" "/header" etc.).
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 12-16-2012 at 07:17 PM. |
#29
Really hope it improves this time and won't fall back to lag mode in a few weeks!
#30
As I said before the car is performing great now. No hesitation at all. I did have a problem where it would start off in second gear and then with no extra pressure on the gas pedal, it would all of a sudden down shift to first gear like it couldn't figure what gear it should be in. That is totally gone now. I hope this a permanent fix now and the adaptive controls don't screw it up again. |
#31
Hesitation software update
Gents- So I too have had an update done to attempt to correct this issue. The dealer did the update and it was documented as "bulletin 12 09 11"
I do notice a big difference, but has there been another update in addition to this one, and since I think it's fixed, I am wondering if there is another that improves the fix even more. |
#32
Is it not a "delay in engine response", aka "hesitation", aka "tip in"? If so, then SI B24 02 12 dating back to March of this year is that document: The issue then was EGS (transmission) and DME (motor) software calibration was "unfavorable". Now it seems there may be another new SIB addressing it again.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#34
Awesome!!!! Thanks so much!
If there is a way you can get a physical copy from your S-I-L, I would be most grateful. If you don't want to share it here, just PM me for my email, if you can get that lucky. Thanks!
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
#36
Is there any way to determine what versions our cars have and what versions are available? Thanks!
#37
What do you mean by what versions are available?
#38
#40
Will do. Thanks.
#41
The new SI B12 17 12 is again for "delay in engine response" with N52T / N55 Engine and 8HP45 Transmission to 03/31/12, and is a follow up to and replacement for the above SI B24 02 12, and the problem remains unfavorable EGS and DME software. The fix then was ISTA/P 2.46.0 (or higher). Now it is ISTA/P 2.48.1 (or higher). So, the "tip in" problem has now been documented, not once, but twice.
#42
Anyone know if the fix addresses "take-off" hesitation or only while decelerating?
From reading the SIB, the update only addresses a certain use-case which may not be the main complaint on this forum. It was my understanding that the main complaint was hesitation in general.
2012 535i Last edited by sdbrandon; 12-17-2012 at 12:58 PM. |
#43
#44
2012 535i |
#45
Still too early to tell because the car might seem ok and wonderful for the first week after the update, then deteriorates and returns to square one. Happened in the previous "global update", and I'm not holding my breath on this one.
#46
Yeah, me too.
#47
My tip-in and idle surge problem was resolved after the last update (and from wiping out the previous learned data). They also re-programmed the steering module on that visit and fixed the mild pulling issue of the MY2011s.
2011 535i Sport (Prem 1, 2) |
#48
On a related note - especially since Shawn is following this thread. Can the car be coded to start in first gear even when not in sport mode? I assume all 5's start in second when not in sport mode, but my 550 does for sure. I'd love to change that.
2012 Acura TL SH-AWD---Wife's car 2013 BMW 1600 GT---2011 Kawasaki Ninja 1000---2012 Ducati Panigale |
#49
Not that I have seen, but I have not spent a whole lot of time in the EGS or DME Modules either.
#50
Sounds like a great New Years Resolution Shawn
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
