I need help with code PO174 bank 2 too lean - Bimmerfest - BMW Forums
Old 05-27-2015, 05:54 PM
johnpark johnpark is offline
Mein Auto: Indiana
Hi guys I have 2003 325i, this is my first time posting here and I know there is a lot of solution out there about this specific code. But I just wasn't sure which one was the right solution in order to fix it. First of all the SES code came up randomly one day whenever I was driving down the highway and I checked at autozone and it said it was PO174 bank 2 lean. I have cleaned the mass airflow sensor, cleaned out the fuel system with "gumout/ expert series fuel system treatment",did not checked the vacuum hoses since I wasn't sure if its either the air intake or the fuel problem..... My car seems to loose power from a cold start whenever I am trying to drive around.. Is there any solution for this situation?
Old 05-28-2015, 05:15 AM
Scott ZHP's Avatar
We want the Lion!
Might want to use the search function. This has been asked dozens of times. A lean condition is caused by either too much air, from a vacuum leak, or too little fuel. Fuel issues could be a clogged/dirty fuel filter of a failing pump. It can also be caused by a failed MAF that incorrectly calculates the volume of air; and no amount of fuel trim will resolve this. Clogged cats and excessive exhaust back pressure can also cause this code.
e46 325i 325i sedan
