E46 (1999 - 2006)
Old 01-20-2013, 08:38 AM
Nigel-Author Nigel-Author is offline
Mein Auto: BMW 318i SE Touring 2004
For the record, this problem does tie in with me having all the BMW stereo replaced with a better one, including two Genesis amps in the boot, a sub woofer, four new speakers in doors and rear, and head unit. They also wired the Tomtom satnav power lead off the Alpine head unit rear so I don't have to plug it into the ciggy lighter.
Could it be that any of this is causing the issue?
Old 01-21-2013, 05:02 AM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 2007 335i
Anything is possible but not likely that putting a new stereo and speakers would cause engine/tranny electrical problems. Did you have the fluid/filter change done?
94 318i, 97 528i, 07 335i
Old 01-21-2013, 05:53 AM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Send a message via Skype™ to Dave 330i
Mein Auto:
Am I correct to say from all the posts that the problem still exists, and everyone is scratching his head not knowing what the issue is, and that the only solution is to replace this and that? Do mechanics still exists when automobiles have become so complicated the only solution is trial and error by replacing electronic boxes or reinstall software?
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 01-21-2013, 06:09 AM
vandyboy vandyboy is offline
Mein Auto: 2001 325i
Nigel: I just went through a weekend of the same kind of BS you are experiencing. I did some stereo work and did not disconnect the negative cable of my battery. I turned the car back on and had that stupid transmission fault code in addition to a plethora of other issues. I disconnected the negative cable for 20 minutes and put it back on - no more warning lights and everything worked.
I know this sounds simplistic and some experts will roll their eyes at this suggestion. Your mechanics have probably disconnected the negative cable fixing other things, but why not try it again? It will not cost you anything and its worth a shot.
