E34 (1989 - 1995)
Old 12-17-2012, 12:22 AM
geoffrey.whale@ geoffrey.whale@ is offline
moby ****
Mein Auto: 1989 BMW 525i
Wink hOW LONG TO REPLACE TIMING BELT
In order to try to price the job, can anyone tell me the approxiimate time (hours) to replace the timing belt on a M29 motor
Old 12-17-2012, 02:52 AM
BMWFatherFigure's Avatar
Old School
Takes me best part of a day, but I'm a fussy bastard.
Current:
E38 Parts Car
Previous:
Old 12-17-2012, 03:25 AM
Banned
Mein Auto: car
Takes 90 minutes, including timing bearings, for ordinary folks . Takes longer if you flush the radiator first, and even longer if you are doing the water pump and thermostat.
Consider changing your rad hoses, metal coolant pipe, fan clutch and engine belts to maximise your labour. Also have your pulleys inspected for damage, your tensioners inspected for errr loss of tension. This might also be the interval at which you need to adjust your valve clearances (cant remember please check the bentley manual).
Old 12-17-2012, 03:27 AM
Banned
Mein Auto: car
Respray your fan's blades with matt black paint when its out, on both sides. Trust me will look purty.
Old 12-17-2012, 04:54 AM
south26 south26 is offline
Mein Auto: 535i 1989
For your first time figure 3 hours. It is suggested that you replace the tensioner. If you do not know the last time the water pump was replace I would also do this. The rest is just nice to do.
Andy
Old 12-17-2012, 02:56 PM
moby ****
Smile
Thanks guys. I now know what I am up to.
Old 12-17-2012, 03:16 PM
Banned
Mein Auto: car
Andy
Do you mean the timing belt's tensioner ? Should this be replaced at each tb change, or every alternate change ?
Old 12-17-2012, 03:54 PM
I replaced the tensioner every other time along with the water pump.
Andy
Old 12-17-2012, 03:59 PM
Banned
Mein Auto: car
Andy
Ok, so both water pump and timing tensioner at every alternate timing belt change. Roger wilco..
Old 12-17-2012, 09:12 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
2-3 ours for your first time, i would expect a BMW specialist to be able to tackle this in 1.5-2 hours MAX.
Also makes sence to do waterpump while you are down there unless you have a history of it. also tensioner should come in any M20 timing belt kit.
(By the way, as far as i know there is no such thing as a M29 motor, i assume you mistyped and ment to say M20?)
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 12-21-2012, 01:08 AM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
Don't paint your fan with paint, you're just going throw it off balance and make it eventually explode. I don't know how you're still on this site, Roberto. You're lack of knowledge is honestly hilarious. I can't fathom how you still believe the words that you type onto your keyboard.
Old 12-21-2012, 04:31 PM
moby ****
I am wrong again
You are right it was a typo on my part shud have read M20. Thanks for the gee up.:
Old 12-27-2012, 09:19 AM
Banned
Mein Auto: car
1. We are talking about **spray paint**, not thick weatherbond emulsion house paint that is applied with a brush or a roller. Google for instructions on using spray paint and you'll see that we're talking about thin layers here. And this is on both sides, and in any case, any lack of balance cause by apparently uneven spray painting is insignificant in the context of a viscous fan clutch of that size. Just look at it rotating at idle and you should be able to assess this easily.
2. Spray painting is better than cleaning or leather/rubber spray coatings as a clean faded fan remains faded still and the leather/rubber conditioner does not last long in a hot environment. With spray paint, you've got a good 2 years on it.
3. Painted clutch fans and shrouds are plenty purty. Hi temp paints are not necessary but are nice in any case.
4. Clutch fans do not explode spontaneously, as the word 'explode' tends to invoke in the untrained mind. Perhaps you missed this thread.
http://www.bimmerfest.com/forums/sho...d.php?t=658749
Read it and other threads on the E39 forums on this subject carefully.
Old 12-27-2012, 05:17 PM
Tyannt Tyannt is offline
Send a message via Yahoo to Tyannt
Mein Auto: 95 540/6 Alusil
Link to "clutch fan spray paint" Roberto?
Do want my car to be plenty purty tooo!
Ummm, it's for the blades only, right?
Old 12-27-2012, 07:16 PM
Banned
Mein Auto: car
Well my dear, google IS your friend, but Roberto is your fan, so here you go :
http://www.amazon.com/s/ref=nb_sb_no...mp+spray+paint
http://www.walmart.com/search/search...h_constraint=0
http://www.ebay.com/itm/Dupli-Color-...30abad&vxp=mtr
Basically, walmart and autozone will have stacks of these.
Here are some tips on how to apply spray paint :
http://www.wikihow.com/Do-Spray-Painting
I'm sure youtube has great videos on this. Youtube should be on the "preparatory circuit" for anyone contemplating a DIY project of any shape or size. There are both good amateurs and seasoned mechanics who post videos there for everything. And this applies to any subject
Basically, for the fan clutch and shroud, you only need to apply one coat. Don't bother with more, it doesn't help none. Just make sure the surfaces are clean and free of grease, water and surface impurities as best as you can before you whip out the can.
Merry Christmas Tyannt ! I missed you the most ! )
rgds,
Rob
