BMW Coding and Programming
Discuss coding options and features on your BMW here. |
FSC to CCC
hi
I'm looking for help with typing the code FSC to CCC by Tool32. i greet |
What do you mean, "typing the code"?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 12-17-2012 at 09:39 PM. |
hi
CCC damaged - exchange, the lack of voice control I greet |
So you have a new FSC Code for Voice Recognition that matches your Vehicle and CCC VIN?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
any info appreciated
I PM'd you a ton of information...and based on that, what is still unclear?
thank you very much the problem as I have already written argument?
1) VIN B293747 needs to match CCC and the FSC Code, and the Car itself. Without a 3-Way match, it won't work. 2) There are VERY FEW people that know how to use Tool32 to Import and Activate FSC Codes. I am NOT one of them. ![]() I do know that with 00SWT.prg, these are the jobs, but I do not know the arguments. FREISCHALTCODE_PRUEFEN FSC check FREISCHALTCODE_LAENGE_LESEN FSC long read FREISCHALTCODE_SCHREIBEN FSC write you can use the 64bit FSC long word from the .FSC with this one. I think also for FREISCHALTCODE_SCHREIBEN, first you have to do an authentication somehow with jobs "authentifizierung_zufallszahl_lesen" and "authentifizierung_starten". 3) Other people use a program called FSTool (Freischalt-Tool), not to be confused with FSCTools, which is an entirely different program that does not do do Import and Activation. You will likely never get your hands on FSTool (Freischalt-Tool), as the few people who have it, will NOT share it. 4) The FSC B293747.ZIP contains no actual FSC Code. The B293747_00020001.der file is only a certificate for the FSC Code, which you do not need. The FSC Code file name would be B293747_00020001.FSC. I think the B293747_00020001.xml file is the ****** FSC Code embedded in a XML File. Maybe this can be converted to the .FSC file, but I do not know how. The other option is to use ISAT/P. Have you considered that?
If his OP vehicle is 2007 and below he needs the CD that has FSC codes for CCC and code with PROGMAN not with ISTA will be the prefer method[specially it is used].
Hi
I've got the FSTOOL 2 - but it's with BMW TEST Certificates and cannot be used for anything... But is someone knows someone that has a WORKING FSTOOL 2 - I'm interested Rgds Jesper |
PM sent.
Hi I'm looking fstools 2, please PM me. Many thanks.
FSTool is near impossible to get.
I would PM Ysseydk, as he announced he has this program. Are you trying to generate FSC Codes, or import and activate FSC Codes, and for what chassis?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 04-30-2013 at 11:50 AM. |
I would like to replace the CIC on e70, so I have to put FSC code in the new cic.
There exists another program though that is easier to find that is developed by Bimmer Retrofit called "CIC Special Service Utility", that supposedly works just as well. Try searching for this one too.
I have BMW CIC Special Utility 1.0.4352, it does not work, I can only read FSC.
There is a "cracked" version that supposedly works.
You can find out where to download it?
This is not a original installer, this is a working version? Thank you, I will try.
Yesterday I read out the stored FSC Codes in cic with "CIC Special Utility 1.0.4352"
I saved them as files and compared the 9c FSC with the one I have from Dealer. comparing the saved FSC with "CIC Special Utility" to the original from Dealer, I saw that the saved one is really short and completely Different. Don't know if importing would work. What is the difference by the "cracked" version, and can anyone share it for testing? |
Hi Shawn. Are there any news about fstool2 or cracked CIC Special Utility 1.0.4352? I have not found anything.
You can always just use an ISTA/P VM for both Exx and Fxx FSC Code Importing and Activating though, so I do not see why these old programs are sought after.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
