Old 12-17-2012, 08:56 AM
kofoedp kofoedp is offline
Mein Auto: 2001 740i
740i ABS-DSC etc.
ABS DSC lights are on, speedo not working and temp guage at max. Leave the car for a day then all is normal. After it warms up, the problem returns. Help.
Old 12-22-2012, 01:56 PM
a1exander a1exander is offline
Mein Auto: e38-e30-e36
The ABS and DSC are influenced by the speedometer.
The issue of the temp gauge being full to the right and the speedo not working indicates a cluster issue maybe with earthing or the internals.
I would try and diagnose the instrument cluster first.
Old 12-23-2012, 11:01 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
The wheel speed sensors influence everything ABS & DSC, so I'd do the 15 minute quick test of the wheel speed sensors pretty early on in the OP's diagnosis:
- ABS DSC diagnostic DIY
Old 12-25-2012, 03:11 PM
First740i First740i is offline
Mein Auto: 740i
I had the exact problem it was my right rear wheel speed sensor. 50 bucks. Not hard to fix but not easy. Takes some finesse to get out it its a old rusty car.
Sent from my DROID4 using Bimmer App
Old 12-26-2012, 05:48 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
My 5er is doing the exact same thing, accompanied by transmission failsafe mode. Sent my ABS module to module masters and they said it was damaged beyond repair, so my assumption is you'll need a new module. I haven't bothered to put one in yet on the 5.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-29-2012, 11:30 AM
mike213735 mike213735 is offline
Mein Auto: 2000 728i Sport
I had a similar problem. No speedo, no cruise control, no analogue MPG gauge.
Tim put another ABS/DSC module on and everything works now. The module does have other faults though, so I'll be sending my unit off for repair.
Mike
Old 12-29-2012, 03:25 PM
setconstr setconstr is online now
Mein Auto: 2001 740i spt 2008 cl550
re
The speed sensors get dirty and their easy to clean i bought a little wire brush like 3/8 diameter so i could clean the hole out. I used brake cleaning fluid and it just takes alittle time to jack the car up and remove the wheels for easy access but you can look for frayed wires and its a good time to clean the inside of the wheels ..........Here is a good write-up
http://forums.bimmerforums.com/forum....php?t=1815681
Old 12-29-2012, 10:19 PM
bluebee's Avatar
Here are all known replacement options:
- What are all known options when your ABS control module is bad (1)
Originally Posted by setconstr View Post
Nice find. I'll add it to the canonical set of links for the trifecta:
- How to diagnose the BMW amber ABS BRAKE DSC/ASC trifecta or bifecta (1) & what are all known options when your ABS control module is bad (1) & Quick99Si's explanation of why the 10-minute wheel speed sensor diode-action quick test doesn't always work, especially on brand new non-OEM wheel speed sensors (1) (2) & explanations by 540iman as to why the fancy diagnostic tools very often (extremely often, like almost all the time) fail to properly diagnose the trifecta or bifecta (1) (2) (3) (4) (5) (6) & where to get the fancy schmancy diagnostic tools for free once you're aware of these limitations (1) & an ABS BRAKE DSC trifecta brake pressure sensor diagnostic DIY (1) & how to test and replace the steering angle sensor (1)
HTML code is Off
