E34 (1989 - 1995)
Old 12-17-2012, 09:49 AM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
Rubber boot falling from wipershaft drive rod
Hi everybody.
The piece labelled #6 as deteriorate, making the drive rod (#7) fall from the wipershaft mechanism and causing a no windshield wiper condition (and now it's raining a lot in Azores).
Does anybody knows how the rubber boot (#6) is attached to the drive rod???
As a quick fix, I drilled a hole throw the drive rod, then run a piece of wire with a bolt on the drive rod to split the wire in two and tight it on the other side of the fixed ball. Better solution for this???
Best regards
Old 01-04-2013, 09:55 PM
virgontour virgontour is offline
Mein Auto: 535i
did you spray paint the wire black ! if so leave it
