E36 (1991 - 1999)
Old 12-17-2012, 03:18 PM
harobe harobe is offline
Mein Auto: 1995 325i
Upper neck broke off radiator, need help.
After a new waterpump and hoses, now the upper plastic neck on the radiator broke off of my 95 325i sedan. It has 220,000 miles on it.
Does anyone know where there might be instructions to R&R the radiator?
What else should I replace while there?
Best place for parts?
Old 12-17-2012, 03:22 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Here is a tutorial for radiator replacement, but you will also find countless other tutorials by searching Google for "E36 BMW radiator DIY".
http://www.pelicanparts.com/bmw/tech...eplacement.htm
Also, the entire cooling system needs to be replaced in these cars every 75-100k miles before something breaks and the engine is overheated. Since you've replaced the water pump and hoses already, that leaves the following items needing to be replaced:
- Expansion tank
- Expansion tank cap
- Bleeder screw (replace with brass)
- Thermostat
- Thermostat housing (replace with aluminum)
- Fan
- Belts
- Radiator (or course)
A couple of good places to buy parts are FCP Euro and GetBMWParts.com.
1998 BMW 328is
1966 Pontiac GTO
Old 12-26-2012, 08:23 AM
- Expansion tank
- Thermostat
- Fan
- Belts
ZeGerman, thank you so much for your reply. It was a huge help!
Old 12-26-2012, 11:59 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '96 328iC, '04 325Ci
ECS Tuning is a good source too.
They're located in Ohio too (Wadsworth) so that will help keep your shipping charges down.
If you go to Bonehead Performance you can get an all aluminum Mishimoto radiator for about the same price as the OEM and it will have a lifetime warranty.
'96 328iC "Marie"
