E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
What manufacturer for a replacement battery?
I need to replace my battery but am not sure what is the best brand to use. Also how many CCC should the replacement have? Thanks
Consumer Reports rated Napa 84 as the best.
interstate and 600cca will be more then enough. if you want to drop the coin, optima yellow top.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
THere was another thread on this site giving just about every battery 'name' and true source. I think it was on the E34 area.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
advise staying away from the E34 area at the moment, its another classic bimmerfest war ground right now
My battery would not hold a charge, had to buy one right away and the best available was an ACDelco 700 CCA. Working good now and has a 3 year no questions asked replacement warranty. Thanks for the advice
Yes it is lol.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
Good choice, I went with the Ac/Delco as well. My work (Koi Autoparts) sells the hell out of them.
I have the Kirkland from Costco. $64 with 90 month warranty or something like that.
In 2003 I bought a Volvo for my wife. I don't know how old that DieHard was, but it's still strong today. Car can sit for long periods, or driven daily, no matter how cold, it does not lose any power. I bought another one for my other car, and expect the same, it's been only two years. $100 at Sears.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
