BMW Coding and Programming
Discuss coding options and features on your BMW here. |
I'm F20 118i owner, and my F20 come with 205 AT gearbox without shift paddles.
After read through realOEM I started to try retrofit the shift paddles, I've ordered the +/- paddles set and the steering wheel connecting cable. I've changed the FA 205 with 2TB, then CODE the whole SVT tree, but the shift paddles still can't work. May I get any hints that if I need to add/modify additional FA? Or I can't retrofit shift paddles just simply by coding? Thanks. |
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
Expert Mode->Coding, Read Vehicle Order, Read (VCM), Save the xml, Edit FA-Editor, right click FA, calculate FP, goto SALAPA-Element, changed 205 to 2TB, apply, calculate FP, save return to Export Mode->Coding, Load the xml, right click on FA, activate FA, Read (VCM), single click on the root SVT then click Code button |
Maybe check EGS for Sportschalter and Sportschalter_alt and make sure both are set to Aktiv just in case the VO Coding didn't do it.
I've checked ICM after I coded 2TB, IcmKod_B_S2TBA become verbaut; and IcmKod_B_S205A become nicht_verbaut. So I am not sure if I need to do additional coding to make the paddles works. Or, maybe I'm lucky enough to receive the DOA paddles?
Checked EGS / 3000 Applikation / Sportschalter and Sportschalter_alt, both are aktiv already, and I even changed KOMBI / 3000 Anzeige Konfiguration / SPA_SPORT_ENABLE from nicht_aktiv to aktiv, still can't make the paddles works.
Any other coding I should try? |
Off the top of my head, I don't know what else would be needed to enable the Paddles. I will do a little more digging around though.
Not familiar with this chassis, but do you have an SZL/SWS module? Check in there. That's the steering control module that your wheel is mounted to. It's the primary electrical connection from the steering wheel to the car. You'll probably see a schaltwippen or other setting that needs to be enabled.
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
Check FRM module. There are many functions contected with buttons, controling, etc.
Try FEM_BODY instead. That is a catch-all on F20/F30 chassis.
I've access to a F20 M135i yesterday, which original come with SAT and shift paddles, apart from the interior/exterior/rims, there are the different as follow:
118i : M135i 255 : 710 7AC : not exist not exist : 957 will these different helps? |
P7ACA BMW Sport Line P957A HK-Paket
7AD urban line of 118i F20 didn't have sport+ mode, but after changed to 7AC, the sport+ mode come out |
It could be...
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 12-22-2012 at 05:50 AM. |
Hey, simonchs, I also own an 118i with the 205 8AT transmission, and I am very interested in retrofitting paddle shifters myself.
I haven´t purchased any of the parts I need to do this yet, but I was wondering - when you changed the coding from 205 to 2TB was there any difference in your gearbox' behaviour? I mean, did the gear changes get any faster, and more importantly, when driving in sport+ mode does the gearbox now let the engine hit the rev limiter instead of upshifting automatically? Cheers! |
still no luck, i've changed 255 with 710, removed 7AC and added 957, and even changed to another set of shift paddles, still can't get any respone from the paddles...
Anyway, does it at least behave like the 2TB now that you've altered your car's code? |
is there any tools to compare cafd files? if there is, i will start to compare cafd file from M135i F20 with my 118i F20
the response time of gear switching "seems" faster, but i don't have any scientific method to measure it...
I guess it is pretty much impossible to measure shift times... But try to hit the rev limiter while driving on sport+, if it upshifts automatically instead, than it's still behaving like the 205.
You cannot create text trace files in E-Sys like you can in NCS Expert.
#25
Good luck!!! We´re in the same ship |
| Bookmarks |
| Tags |
| shift paddle |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
