BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
Have you added 2XA with 2TB? |
#27
Yes, I have added the 2XA with 2TB but I got nothing, cos sowftware of my car has got in the Module ICM (CAFD_0000067B_002_002_0049) C_MF_LENKRAD, VALUE=INSTALLED, so disable the SALAPA element 2XA in all models F2X and F3X. so I´ll have to upgrade car's firmware, cos now is posible to order your car with the 2XA option.
In addition, in our cars 2TB option does not exist, therefore if you program your car with this, this will be ignored and it will work with the default which is 205. Calculate FD doesnt give a error becouse the instruction is OK, but not for ours cars, the program is not able to recognize the different configurations made by BMW, to judge whether they are right or not Last edited by kitercarlos; 01-01-2013 at 04:17 AM. |
#28
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#29
This option isnt allow in engines like 18i and 20d, ony 35i 35d
#30
However, I would still expect E-Sys to be unable to calculate FP if an option code such as 2TB was used with an incompatible motor. And right or wrong, if it did successfully calculate FP, I would then expect it to properly VO Code the car for 2TB.
#31
If I added an option unique to another PSdZData set, for example 196 Explosion Proof Fuel Tank from the 7 Series, FP would not calculate, as expected. If I added an option within my own PSdZData set, for example 552 LED Headlights from the 6 Series, FP would calculate, even though 552 is not available on the 5 series chassis. Since the 5 and 6 series share the same PSdZData though, it surprisingly allowed it. More surprising though, it allowed 552 LED Headlights simultaneously with 522 Xenon Headlights, even though a car could have only one or the other. I wonder what would happen if FRM was VO Coded with both in the VO? ![]() Now when it comes to actual VO Coding though, I think some additional logic must be applied as I know for sure it will code the same VO Options differently based on the production date in the VO. So, sadly it seems quite possible that a VO with 2TB and an incompatible motor can calculate FP, and that the VO Coding based on that would still ignore 2TB.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 01-01-2013 at 02:19 PM. |
#33
Do you have another F25 with working paddles that you can check the VO on?
#35
2XA: Sport Steering Wheel with paddles 7XA: M Steering Wheel with paddles 2TB: Sproting behavior of the gearbox and different aesthetics of the gear selector switch. Whit any angine you can order de automatic trans 205 with 2XA since August 2012 Only with engine 35i and 35d you can order 2TB with 7XA. unfortunately I do not know anyone? Last edited by kitercarlos; 01-02-2013 at 05:00 AM. |
#36
Ok. Here is what you do. Go to your local dealer, take "test drive" of F25 with Paddle Shifters, pull around the corner, whip out your laptop and ENET cable, read and save the VO, then return car with your thanks but no thanks on purchase.
#37
#38
Just wondering, F20 M135i which come with 2TB and paddles, don't have 2XA/7XA
#39
The Steering Wheel in covered by S249A Multifunction f steering wheel, and S710A M leather steering wheel. .
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® Last edited by shawnsheridan; 01-02-2013 at 07:28 AM. |
#40
http://www.realoem.com/bmw/showparts...29&hg=61&fg=35 |
#41
The build date is 2011-09-19
#42
http://www.realoem.com/bmw/partgrp.d...US&hg=32&fg=35 |
#43
So did you try changing your VO Production Date to 0812 before VO coding 2XA and or 7XA?
#44
I have the Esys 3.18 Psdzdata 4.47.5 Do I need to upgrade to 4.48.1? Last edited by kitercarlos; 01-02-2013 at 08:39 AM. |
#46
If your Vehicle Production Date is before an Option Code was available, when you VO Code the Option Code will be ignored, so you must change the VO Production Date to a date at least equal to when the option first became available:
#47
Thanks |
#49
Try 0812 as I wrote.
#50
I'm home again, I've changed me VO Production Date to 0812 and I added 2XA but nothing has changed still not working
| Bookmarks |
| Tags |
| shift paddle |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
