E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Carpet removal instructions.
I'm getting water into the cab somehow and it has soaked my carpets, under the passenger seat and passenger rear foot well, driver and passenger front foot wells and a small amount on the drivers rear foot well. Basically I need help removing the carpet. My basic idea is to remove seats, center console, and plastic around the shifter. Any advice would be greatly appreciated! Thanks
yeah thats about it, and rear seat to get the little piece out. I also made sure to have a razor knife to make things a little easier around the center console. My floor and firewall had a bunch of little holes. My front winsheild was also leaking at the bottom of the trim. I made sure to weld in new metal and undercoat the interior floor and underneath, kept my padding out, and re-installed my carpet. Lighter, louder, and less comfort, but no leaks and no ponds on the floor board.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
Door opening trims have to come off as well. (The ones at the bottom)
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Glove box and driver knee bolster and both kick panels, remove hood pull, seat belt guides...
And you have to decide if you want to cut around the HVAC or pull the dash and heater core and all.
the correct way to remove the carpet is (in addition to the above) you need to remove the heater box as well. however most people will cut around that and leave the carpet under the heaterbox still installed. when you reinstall, the console goes back over the top of the join and noone would ever know.
while the carpet is out, its a great time to waterblast the hell out of it and clean it up a bit and/or dye it
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
