Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 07-17-2006, 09:23 PM
Chipster Chipster is offline
Mein Auto: 2003 540-6spd 10/02 build
Question TCU Service bulletin - how long
I'm beginning to think my dealer's service department in incompetent. Has anyone (other than R6Girl) had the TCU repaired? If so, how long did it take. They have had my car since Friday and are telling me they need approval from BMW to repair the problem. I've seen the Service Bulletin and it doesn't look like it should take 2 days.
They did R6Girl's car in 4 hours. Is my dealer BSing me?!?!
Service Bulletin - SI B84 14 06 Phone, Navigation Systems June 2006
"Dream as if you'll live forever, live as if you'll die today."
Old 07-17-2006, 11:17 PM
BmW745On19's's Avatar
BmW745On19's BmW745On19's is offline
Go Gators
Mein Auto: 745i
R6Girl has an X3, you have an M3, two different TCU units thus different times. Get a second opinion from another dealer if you aren't confident with your dealer's work.
Old 07-18-2006, 03:46 AM
Thanks. From the TSB "posted by Cobradav" in another thread it appears that the process is the same, regardless of the vehicle.
None the less they have the car and I have to wait. I just have my reservations about the dealer as they gave me the run around with the installation of the Siruis reciever a couple weeks ago.
Old 07-18-2006, 06:04 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
If you have read any of my past posts on TCU Units, I had 5 of them put in in a 9 month period before they got it right.At one point they kept the car for 5 days because they had to let it go into a sleep mode to see if it was working ok because they were having so much trouble with them. I wouldn't be a bit surprised if they are telling you the truth. I was also told that they have to get approval from BMWNA before they can install them Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 07-18-2006, 08:06 AM
Hi Vern,
I think I did read your post about the replacement. Are you using the BT feature. My phone would work intermittently then stopped all together. I thought it was my phone but it turns out it was the TCU.
If you're not using the BT, how did you know it stopped working?
Thanks!
Old 07-18-2006, 12:44 PM
Hi Vern,
Thanks!
I was on a trip and had a stop in S.C. when I decided to check the S.O.S. for a location and it wouldn't go through so I called them on the cell and they told me I lost contact and it was probably my T.C.U.Unit and I should take it to my dealer to get it corrected and they would notify the dealer,(JMK), and BMWNA of the problem. Take it from me, its a very good idea to check it often.Good luck I don't use the BT.
cheers
vern
Old 07-18-2006, 04:46 PM
Ajax's Avatar
Ajax Ajax is offline
Hydrocarbon Man
Mein Auto: 991 GT3
My Assist NEVER worked properly, despite numerous visits, calls, etc. I gave up on BMW and losing the radio function while I was busy "testing."
POS imho.
Hard to believe GM could get something like OnStar to work pretty much flawlessly and BMW can't.
Old 07-18-2006, 06:11 PM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
Replacing the TCU on an E60 5-Series does require authorization and it seems often a reload of the car's software as well.
2010 BMW M3 Coupe M-DCT w/Tech-EDC, BMW M Performance Exhaust, BPM Stage I Tune, Space Gray / Fox Red Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2011 BMW 135i M Sport DCT, w/BMW Performance Power Kit, Exhaust, and Brake Rotors, Space Gray / Coral Red, known as "Stiggie" with an outlaw F20 "M135i" badge.
Old 07-18-2006, 08:04 PM
JSpira's Avatar
JSpira JSpira is offline
Freude am Fahren
Mein Auto: Fünfer und Dreier
Not really a reload but the sw must be upgraded to the latest PROGMAN.
Freude am Fahren.
-Jonathan
F10 2014 535d M Sport Mondstein Metallic
F10 2012 ActiveHybrid 5 Azuritschwarz Metallic
MB 2011 E350 BlueTec
E70 2011 X5 xDrive35d*
E90 2010 335d*
E60 2008 550i*
E90 2006 330xi*
E90 2006 325i
E90 2006 330xi*
E39 2003 530i*
E46 2000 328Ci*
E36 1996 328iS*
E36 1992 325i*
E30 1991 318is*
E21 1982 320iS*
E21 1979 320 (6-Zyl)*
*retired
Old 07-19-2006, 09:06 PM
Rocket Scientist
That's what I meant. I ended up having a PuMA case that lead to my car getting 20.02 which is actually not an E60 related release. The thing works which is good enough for me.
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
A story about a good service department (long) KP General BMW Questions 8 12-31-2007 12:19 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 04:59 PM
when should i get my oil changed? ///M3 Wes 1M & M2 13 04-28-2003 10:59 PM
