Old 12-20-2012, 05:47 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
possible to code FTM instead of TPMS
would this be possible for a US spec car that has tpms (sensor based), to enable FTM (abs sensor based monitoring)
rest of world inc canada use FTM for the F30.
car is coming tomorrow, so i shall dig, but was wondering if anyone tried this vs disabling tpms.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 12-21-2012, 06:26 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
I don't see how. Unlike TPMS, FTMS has no actual pressure and temperature sensor, and it uses only tire rotational speed to determine if a tire has lost air pressure. If you have TPMS, I do not think that you will be able to disable it and enable FTM in its place.
Why would you want to do this? Most everyone else with FTMS longs for TPMS.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 12-21-2012, 10:05 AM
winter tires-- i currently have the wheels off of my e90 with incompatible sensors. if its not possible i guess ill just bite the bullet and get new sensors and have the wheels broken down and installed.
