Old 12-20-2012, 06:15 PM
707E38707 707E38707 is offline
Mein Auto: 2000 740i
Rattling noise in first gear.
Has anyone ever experienced a rattling noise in their E38. The noise sounds like its coming from either the center or passenger rear of the car and it only makes the noise when the car is rolling from first gear to second. Once the car hits 2nd gear it stops and it only makes the noise if you accelerate. A friend of mines said it could be something dealing with the drive shaft.
Old 12-21-2012, 05:41 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
If the sound is comeing from the rear then yes. Its most likely something with the driveshaft or diff.
Old 12-21-2012, 11:56 AM
BMWFatherFigure's Avatar
Old School
Check the drive shaft support bearings and housings.
Current:
E38 Parts Car
Previous:
Old 12-22-2012, 09:00 AM
First740i First740i is offline
Mein Auto: 740i
Could also be tyranny fluid levels!!!
Sent from my DROID4 using Bimmer App
HTML code is Off
