BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Rear or Top view CAMS while going forward?
Is there a way to turn the top view or rear cam on while going 20mph on a 2013 F10?
D_SCHWELLE_1 = max distance in meters to disable top camera view - Change to Werte = FF D_SCHWELLE_2 = max distance in meters to disable rear camera view - Change to Werte = FF V_SCHWELLE_1 = max speed to disable top camera view - Change to Werte = FF V_SCHWELLE_2 = max speed to disable rear camera view - Change to Werte = FF
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Thanks, I got it to work.
The issue I had was I had to restart the car for it to take effect and the fact it changed the value to "unknown". |
How can i set that the camera screen will automatically close when driving forward but while driving, if i want to view the rear camera (please dont ask why) i could by pressing the pdc button? Thanks |
You can't.
the automatic close is determined by those 4 parameters. when set to "FF" they won't close automatically because D (Distance) and V (Velocity) are set to infinite. when set to anything lower they will close automatically according to the set values and you cannot enable them by hitting PDC while driving any faster or after the set Distance respectively.
BMW GT 530d (MY 2013) |
this is what you will have to try for yourself, I won't do it for you......
Asking for your opinion since there is a slight chance you have more experience but obviously you are hallucinating Last edited by coco135; 03-09-2013 at 08:11 AM. |
keep your guns in your holsters :-)))
meaning that you have to try it for yourself says clearly that I haven't tried it yet and not plan to do so.....
Lighten Up
I'm sure his response was because of the language differance. I bet his English is better then your Austrian. |
I have coded these for the rear cam and it can only be activated while doing < 20-25 mph and it will be deactivated automatically when doing > 50 mph. Does anyone else have a different experience? |
Here is an update...Yes, i did try my self o_0
Setting: V_SCHWELLE_1 V_SCHWELLE_2 To werte=80 equal to 128kph or in that case it is also 80mph D_SCHWELLE_1 D_SCHWELLE_2 To werte=32 equal to 50meters now i can turn the rear camera at any speed up to 80mph (you can set it up to higher speed just remamber to convert kph as decimal to hexadecimal) The camera will close once i drive more then 50 meters (you can set it up to longer distance just remamber to convert meters as decimal to hexadecimal) Conversion can be made easily here - ignore the binary, its not being used. http://www.mathsisfun.com/binary-dec...converter.html Last edited by coco135; 04-09-2013 at 01:32 PM. Reason: adding link |
I changed the following values on the F01 (2009 build) but only the side camera works at any speed not the rear camera. Is this common for an early model or missing some this else.
PDC: D_SCHWELLE_1 Werte=FF D_SCHWELLE_2 Werte=FF V_SCHWELLE_1 Werte=FF V_SCHWELLE_2 Werte=FF TRSVC: SV_Activate_Speed_Limit Werte=FF SV_Deactivate_Speed Werte=FF |
look at the post above yours |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
