Old 12-22-2012, 12:26 PM
nitrydr1600 nitrydr1600 is offline
Mein Auto: 1997 z3, 1982 corvette
97 z3 1.9
just bought this car with blown head gasket. repaired that and car is hard to start. restarts are terrible and have to let it sit for a hour sometimes. also clicking noise sounds like comming from intake area. first bmw and im lost. Im sure o2 senser is probably bad from coolant on it. ANY help or advise would be great. thanks
Old 12-22-2012, 05:08 PM
marty505 marty505 is offline
Mein Auto: 99 Z3 M Coupe/99 540i
Did you do the head gasket yourself or pay someone? That it runs is a good sign, but there are many things that could go wrong when replacing the head gasket that could cause trouble. Getting one of the cams off by a tooth comes to mind first but injectors not hooked up right, crimped fuel line. big air leak, MAF sensor not working properly, there are a lot of possible culprits. How about the plugs? have you pulled them and looked at them, and maybe run a compression test while you're there?
Old 12-22-2012, 05:29 PM
bought car not running and cam gears are correct. it will start and run but seems like when its warm its almost flooded . dont smell fuel but wont fire unless it sets for 2 hours. regulater perhaps????????? my first bmw and quite lost!
Old 12-22-2012, 06:45 PM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
You could buy an inexpensive code reader, or if the car will make it, go to an auto supply shop that will read the codes. The codes might be a good place to start seeing what the engine is complaining about.
I bought this reader from Amazon:
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Old 12-22-2012, 07:05 PM
thanks for the link. i just bought 1 myself. appreciate the help
