Old 12-22-2012, 06:07 PM
ahmadr ahmadr is offline
Mein Auto: F30 (N20, 7/12)
Speedometer correction, digital speedo
Folks,
I can confirm that (similar to the f10), it is indeed possible to enable the digital speedometer and (edit: not) remove the built-in error in the speed display (~5% extra) through coding on the f30. The digital speedo appears as an option you can scroll through alongside mpg / average speed / range / ...
Under BKOMBI, 3000 Anzeige_Konfiguration, the settings are:
BC_DIGITAL_V (activate to get the digital speedometer option)
BC_V_KORREKTUR (deactivate to remove the built-in error. Edit: not)
After changing those two ettings, both the digital and analog speedometers display the unadulterated speed
This was tested on an early 2013 with the regular cluster, no HUD.
Old 12-25-2012, 01:10 AM
Ok, I take that back.
The digital is still 2% high, and the analog 3%.
Pretty much what it was, I guess
Old 12-26-2012, 04:25 PM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
Maybe this post can help you fix the speed issue:
http://www.bimmerfest.com/forums/sho...d.php?t=665603
Old 08-28-2014, 02:54 PM
POizOn POizOn is offline
Mein Auto: 320i
Hi guys,
Recently coded this on my BKOMBI on 2014 F30 320i.
Works great, but the outside temperature is now showing wrong figures - twice or 1.5 higher then it is.
Any ideas?
Old 08-28-2014, 02:55 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
That is normal, and happens every time Kombi is coded. It goes to 122 degrees. Over the next hour it will gradually drop and settle back at ambient temperature.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 08-28-2014, 03:01 PM
Mein Auto: 320i
Thanx Shawn!
Taking barbitudes back to the first aid kit
