E34 (1989 - 1995)
Driver Seat Stopped
Hi all.
I was working on my 1993 e34 front seat, fixed adjustment cables al was working well. Started putting things back together, seat moving and all that, put rear bolts in and the seat stopped responding to anything, switch does not work at all, not bottom, not back. Tried same switch on the pas. side , works fine, pas side with pas switch, works fine, the seat is stuck in forward position so I can't remove it as the front is not on bolts bit on hook brackets, sort of slide for and up and remove it, with seat forward, cant get it off. Pleeeease tell me there is some simple thing I am overlooking. thanks |
I would find the seat circut fuses and test for contunity .
I would check the plug you may have not connected it properly , it nay have worked its way lose
Sent from my Desire HD using Bimmer App |
+1 on both suggestions above.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
You must have pinched the wire under the seat frame when tightening the bolts.
You can still move the seat manually, instrucionnes here: http://forums.bimmerforums.com/forum....php?t=1742710 |
fixed this
I have figured it out, thanks, for all the posts.
Here it what it was, the fuze went out., I discovered a frayed wire on the switch, it was shorting on the seat sled around the switch and shorting the fuze, so I fixed that and it worked great. Thanks again, little help is always good. |
Glad it was something simple.
| Bookmarks |
| Tags |
| 1993, e34, electric, seat, switch |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
