The X5 SAV Forum
Old 04-23-2013, 02:23 PM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
04 4.4i X5 TRANSMISSION IS KICKING HARD
I had this problem too when I had my 2003 X5, they had to replace the whole transmission, I was lucky that there was still 2k miles left before my original warranty expired :X
Old 11-05-2013, 12:06 AM
X3RCGTOrider X3RCGTOrider is offline
RC Car Speeder
Mein Auto: E83 X3,850i, 1969 GTO,740
Was anyone ever able to fix their X5 transmission? We had the torque converter replaced and that solved the problem for ours. It shifts smooth and great again and the terrible kick went away for good.
Old 11-05-2013, 09:25 AM
x_l_r_8 x_l_r_8 is offline
Mein Auto: 2004 X5 4.4i, 2003 530i
Same transmission jerk here on our 04 X5 4.4i with 130K. I was about to change out the trans fluid and filter to see if it would help but my mechanic says don't do it. He's a BMW master certified mechanic and says that if the fluid has not been flushed on a regular basis it contains tiny fragments of the clutch plates. If replaced the transmission could start slipping needing a $6K replacement. Any thoughts?
Old 11-05-2013, 10:22 AM
channingd channingd is offline
Mein Auto: X5
My 2004 X5 4.4 did the same thing. Only when the tranny was cold though. Went away as it warmed up. Simple fluid flush and replacement with new filter. Drove like new, right until by wife rear ended a full size pickup and totaled it.
Old 11-07-2013, 05:45 PM
Kappy21 Kappy21 is offline
Mein Auto: E53 X5
This is a fluid pressure problem within the transmission or in the torque converter (which is external to the transmission but connected to it). It could be simply dirty fluid or a clogged filter which restricts fluid flow within the transmission and a fluid and filter change will fix this. If there is a dirt clog in the valve body, you probably need a replacement valve body since it's very hard to find someone who will rebuild a valve body on a ZF. If it's the torque converter, the torque converter should be replaced before the slamming damages the transmission clutches. The automatic transmission depends on free flow of the transmission fluid through the valve body so that the proper gear can be selected at the proper time, all of which is controlled by fluid pressure. When there is a small blockage, the transmission can't change gears in alignment with engine speed and you get the slamming. Slamming is a different problem than slipping which would indicate that the friction surfaces on the clutch packs are worn and heading to failure.
It seems that new car dealers, particularly the European brands, view transmissions much light bulbs: If it doesn't work right, screw in a new one. They don't seem to have much interest in what happens inside the transmission case or any idea how to fix, or even diagnose, an internal transmission problem. There must be some economic or political reason for this lack of knowledge or interest. I don't know what it is. The best bet is to find a really good transmission specialty shop that has experience with ZF products. A fluid and filter change is probably only a couple of hundred dollars and it's important that it's done correctly since some ZF transmissions need to be filled according to the temperature of the fluid which is monitored as the fluid is added.
Old 11-07-2013, 10:04 PM
RC Car Speeder
We did have the valve body rebuilt as well at first thinking that was the reason for the transmission issues ( Very expensive to have done) it was found that a tube that flows the fluid through the transmission had disintegrated and was causing improper flow which could of been causing some of the issues. The transmission changed afterwards by making the problems different or more noticeable. It was easier for the kicks to happen with the downshift and there some other oddities happening too with other shifts. After we got the torque converter replaced, all those problems were gone.
Old 11-08-2013, 08:06 AM
tolgatt tolgatt is offline
Mein Auto: 2005 BMW X5 4.4 Sport
of course my 2005 4.4 X5 has this issue as well , and I am totally used to not getting it kicked hard by now . I make sure I come to a complete stop , you can also feel at the very last second the gear goes down to first with a slight vibration and then I start accelerating again . Am I happy with it ? absolutely not !
I am still trying to make up my mind if I should get the fluid and filter changed . It doesnt bother me that much so I would pay thousands to get valve body or torque converter fixed.
I forgot who mentioned on earlier posts but yes I think this is a very very very common problem with an expensive fix and BMW should fix this issue at their own cost for whoever takes their cars to their services that has complaints.
Old 01-27-2014, 09:07 AM
roym01 roym01 is offline
Mein Auto: 2005 X5 4.4
Same issue with my 2005 4.4.
Rolling stop, acceleration, slam! Very infrequent, but that was probably due to the fact that I quickly learned that if I came to a complete stop it would not slam.
Truck has 100000 miles and my indie was hesitant to change the fluid/filter. Same advice about not changing the fluid, "if over 100000 and never been changed, don't change".
I changed anyway, fluid and filter but no flush. Couldn't help myself as nobody can convince me that leaving the original fluid in there forever is a good thing. Indie says fluid looked good and filter was dirty. After a week no slams, but not really sure if permanently fixed as now I am so used to coming to a complete stop that I do not remember not to.
I will update over the next few weeks for those interested.
Old 06-01-2014, 03:39 PM
DonJuan DonJuan is offline
Mein Auto: X5 4.4i
Transmission "Kick-down"
Hi Guys,
Been there done it with my X5 4.4i 2005! I had a major problem with "shift-shock" on my X5 especially on the "kick-down"
After replacing the transfer case, various software updates etcetera, I gave up.
Until a very knowledgeable mechanic asked if the "lifetime" gearbox oil had been changed at 80 000 km - which BMW hadn't done while my car was still under Motor Plan.
Anyway, I changed the gearbox oil and the problem disappeared!!!
NNB: With the oil change you'll need 12 litres of the costly oil. You do a 6 litre change, cycle the gearbox thoroughly and replace the remaining 6 litres
This should be the cure for most 4.4i
Depending on the age of your vehicle and the wear on the clutch plates this could also be the cause in some cases.
Old 09-17-2014, 02:43 PM
Just wanted to post a follow up that I bit the bullet and replaced the trans fluid and filter on our 2004 X5 4.4 with 135K miles going against my master BMW mechanics recommendation. Did a complete flush running through all the gears. It "seemed" to help initially but did not cure the problem for the long haul. Now we're at 145K and the trans is kicking again harder than before. It's downshifting pretty rough now as well when coming to a stop at lights. I've read somewhere that replacing the $200 valve body wiring harness (part #24.34-1 423 719) has cured the problem. Of course the oil needs to be drained again and the pan dropped so wanted to see if anyone tried this before going through the trouble. Thanks.
Old 09-17-2014, 04:32 PM
1hander 1hander is offline
Mein Auto: 00 540i M-06 X5 4.4
whats happening to our trucks is plain and simple wear... the fix is to replace the worn parts
the parts that are causing these crazy antics from out trannys are primarily...internal gaskets, orings, solenoids, checkvalves and clutches
the orings and gaskets deteriorate and shrink...when they do this, they allow fluid to leak from its intended path....which also causes a drop in pressure....you give it gas or the rpm goes up a bit..then thhe pressure goes up enough to overcome the loss of pressure...which then allows the upshift or downshift
the internal wiring harness ...the seals harden, they crack...the wires get invaded by oil....you get the picture
there are check balls in the valve body that start a certain diameter...as the trans ages these checkballs get worn down from slamming back and forth.....when they get worn down past a certaion point...they can no longer stop or check the flow of fluid the way that design intended,,this causes fliuid reversion ... pressurized fluid being in the wring place at the wroing time...
of course by then the pressure is higher than design intended...well now the upshift or downshift takes place with a higher pressure than intended and this extra pressure causes the slamming feeling your getting...try to picture rvving the engine on a stick shift and then dumping the clutch ... thats essentially whats happrening here..
shift solenoids get worn and clogged from debris ...they get sticky and do not move freely and will suddenly do what the module asked it to do 3 seconds ago...sometimes you can change the shift solenoids and all will be right again....the shift solenoid are EDS solenoids....meaning they are not the on/off type... they are a proportional solenoid....that is how the valvebody gives nice smooth shifts...by applying an increasing voltagfe to the solenoid which gradually locks it up... the condstant in and out ..in and out,,, wears the barrels and pistons,,,sometimes they get sticky from gunk and particles... and instead of a nice smooth shift it will get stuck and suddenly soot in the rest of the way which gives a nasty shift...up and down
clutches release material into the system.... this material is abrasive in small amounts but after thousands and thousands of miles well you get the idea ... they clog passages and filters... they change the viscosity of the oil..
if the clutches are still good on the tranns, your still looking at a full rebuild...anytyhing less is not realistic, it has to be pulled anyway.....
the reason that some people get mixed results with curing the problem by chanfging the filter and oil..is...the filter does get clogged...and the new oil is just thay...its new...its thicker..not as broken down...
the torque converter could also start to cause problems...just bt the nature if its design...our trucks are old....
mine was shifting crappy.when i bought it.. i changed the oil and filter but did not flush it...flushing a transmission with that many miles on it is a death sentence....but if you have nothing to lose from trying then go for it...
i changed the oil and filter and the shifting was great.. the only thing i have is on its first drive of the day...the 1 to 2 shift is slightly depayed...and the higher rpm fromn the delayyed shift ,makes the shift slightly harsh... but if i just step on the accelerator a little faster it shifts great...weird..
i know im going to replace this trans in the next year,,,thats why i have a transmission from bmw sitting on the floor in the garage...i thought about just doing the valvebody but as far as actually fixing the problem.... that would be like trying to hit a target on a moving truck from a moving truck/// the odds are that it has many other worn parts...i chose not to screw with one grain of sand at a time...
if your having these problem... you need to start saving money...cuz its coming... these vehiclles have gotten so complicated that it is no longer realistic to expect a vehiclle that can go 150k.... no matter how much we pay...
i have a 2000 540i... doesnt burn a lick of oil...6 speed is da bomb if i could found the x5 in MT i woulda bougfht that... it has 199760 miles on it.. nothing major has gone wriong with itr...the x5 has been a different story..
Ret. SSG Gonzales
5th SFG
De Oppresso Liber
Old 10-01-2014, 10:06 AM
gugo63 gugo63 is offline
Mein Auto: 2003 bmw x5
Changing the mass air flow sensor helped with the trans fall safe which took the problem away.
Old 10-01-2014, 10:48 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
Did you reset transmission adaptation after replacing fluid and filter?
Old 10-01-2014, 11:08 AM
I turned the ignition key two clicks and held the gas pedal all the way down for 60sec. I did not hear any clicks or reset indications though. I've also disconnected the battery for 5 minutes but not sure if that will do it. I did not notice the transmission changing gears any differently than before so I guess my method did not work???
Old 10-01-2014, 12:50 PM
hehehehehe this is joke isnt it???
Need to reset it seriously - using computer. Dealers and most BMW independent mechanics have this capability
Old 06-27-2015, 11:24 AM
sambking sambking is offline
Mein Auto: E53 X5 4.4
I don't think so....
Originally Posted by srtudas View Post
Do not bother repairing the transmission because there is nothing to fix. This is a problem on all of the E53 X5's 4.4i. I have the exact same model as you and we have the same problem. Do not try to fix it the thing is this car does not handle those conditions well. I do not know why the car's transmission just doesn't like it. So just to avoid this from happening make sure you come to a complete stop before accelerating. This is very annoying and I wish they didn't have this problem but they do and we love the car enough to deal with it. Hope it helps.
I am sure that most will see the absurdity of the above response.
Here is a great trans rebuild post: http://www.xoutpost.com/bmw-sav-foru...long-post.html
Why anyone would listen to a "nay-sayer" with an entire planet of info being shared on the web is beyond me.
Old 06-27-2015, 11:33 AM
Thanks for this post. It makes complete sense. There is a lot going on in an automatic trans that can go bad over time with regular use. To chance a fix on an existing 100k+ trans is a crap shoot. "Start saving" for a new one is good advice. I think I may install a new trans and then take apart the old one and take a look see, see what I can find and replace everything that I can.
Thanks again for the post!
Old 08-09-2015, 01:28 PM
bar10 bar10 is offline
Mein Auto: 2004 X5 4.4i e53
Solenoid is the problem
I had the similar problem and found after much research that the solenoids can stick if fluid is dirty enough to short out solenoid. I initially replaced fluid and filter, however, this did not repair problem. I then went ahead and purchased solenoid set and additional fluid, including filter. I recommend thectsc.com for contact and purchasing of fluid and solenoid parts. You have no real need to replace the Mechatronic. The Mechatronic actually is the computer attached to the valve body and this is known problem as this transmission is sold on other vehicles. I have a ZF6HP26, on a 2004 X5 4.4i Sport. You can get a re-manufactured valve body with solenoids attached. I am certain it's solenoid short. You can purchase individual solenoids, but I recommend the kit, because the labor to test each one, let alone the tech is not a hack. Usually they don't know a thing. Transmission shop may not be any good to you either. I would start with replacing the solenoids and a complete flush of system with new fluid. Fluid is costly and 8 quarts are needed. Purchase kit from site above and the tech is terrific, but don't expect immediate reply for support. Also, make sure to use only ZF fluid, I had a hack who insisted he used the right fluid until I called each dealer and found otherwise. If wrong fluid is used it will cause many issues were you may feel you'll need a new transmission. I caught his error and he denied it, until I confronted with other evidence. The right fluid is necessary and replace even though dealer says it's lifetime. This should solve your problem. It will run terrific again after reset of shift timing.
Old 08-11-2015, 06:35 PM
Bar10....Thanks for the info
Bar10,
Thanks for the info about your experience with your X5 4.4 trans! VERY helpful!
If what you say works, you saved me a bunch of money, time and grief. Thanks again and keep posting good information for everyone to share!
Sam
Old 08-23-2015, 03:29 AM
Dutchey Dutchey is offline
Mein Auto: e53 X5 4.4i / e60 525i
Hey guys,
Very comprehensive thread! Im looking at draining the trans oil and replacing the filter as I have the same problem. It seems a logical step and a good start.
My question is: What would be a good oil to use? Just the standard or a maybe a different oil as the our transmissions have done some work and have worn a little?
Old 08-23-2015, 10:01 AM
Only ZF transmission oil, your going to have further problems with your transmission with the wrong fluid. Go here to order and save http://www.thectsc.com Fair warning you cannot use regular transmission fluid.
Sent from my Nexus 7 using Tapatalk
Old 08-24-2015, 06:30 PM
leejim leejim is offline
Mein Auto: 2005 X5 4.4 V8
Auto Trans problems.
Hi I had my Trans oil and filter changed at 180,000 kilometers with no resets or problems. It was hanging on in 3,4 and 5 when cold only. Have done 28,000 k since, runs perfectly. I tow a 6.8 m power boat and a 15ft caravan at times. As long as you use a synthetic ATF is all you need. I think some people get a bit carried away with oil brands !!
Old 08-24-2015, 06:36 PM
Good to know. Thanks for posting your observation!
I am going to do a new filter and new trans fluid and see what happens. I'll post my results.
Old 08-24-2015, 06:48 PM
That's why your transmission is sticking and hard shifting. Your wrong and transmission oil type does matter. I have had a hack think just like yourself. The viscosity does have a effect on the shifting points made by the valve body. The mechanic who I told to use ZF brand used something else rather than my strong recommendation using ZF brand. The transmission did slip and skip gears, while hard shifting into reverse. If I did not call transmission shop owner out and contact the dealers who he said he purchased oil from, never saw an order. I forced the shop owner to tow and flush and replace fluid. Not even a problem right after. Shifts were smooth and felt powerful. I would recommend resetting the adaptive shifting to zero too also. You are wrong in your suggestion. Even I emailed a tech from ZF and he would not even diagnose problem until fill and replace of ZF brand oil.
Old 08-24-2015, 07:09 PM
Ouch! Thanks for the info!
(Didn't want to send twice. Trying to delete this one. All I can do is edit it. C'est la vie)
Last edited by sambking; 08-24-2015 at 07:14 PM. Reason: Didn't want to send twice. Trying to delete this one.
transmission, x 5
