Closed Thread
Old 05-09-2013, 06:32 PM
jkelly12 jkelly12 is offline
Mein Auto: 2002 745li
radio,cd, display screen, and idrive
i have an issue that i hope someone else has had. all 4 of these stopped working. the cd player, radio, display screen and i drive knob all stopped working. the idrive usually has some tension on it. it clicks when u turn it. now it just spins freely and the radio does not work cd player does not work and will not eject the disk. the display screen has now power. everything is dead. if i hit the dash or hit just below the screen it will come and and everything will work. sometimes for a few minutes sometimes longer and then while driving everything foes dead. i hit again harder and will come back on. then work for a bit and all goes dead again. now it seems to be really. dead. any idea what would cause all 4 of these to stop working??
Old 05-09-2013, 06:57 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
Originally Posted by jkelly12 View Post
i have an issue that i hope someone else has had. All 4 of these stopped working. The cd player, radio, display screen and i drive knob all stopped working. The idrive usually has some tension on it. It clicks when u turn it. Now it just spins freely and the radio does not work cd player does not work and will not eject the disk. The display screen has now power. Everything is dead. If i hit the dash or hit just below the screen it will come and and everything will work. Sometimes for a few minutes sometimes longer and then while driving everything foes dead. I hit again harder and will come back on. Then work for a bit and all goes dead again. Now it seems to be really. Dead. Any idea what would cause all 4 of these to stop working??
sounds like your ask unit is the problem ...
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 05-09-2013, 07:04 PM
will it turn of the nav screen and make the idrive button not work?
Old 05-09-2013, 07:08 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
yes ...
Old 05-09-2013, 07:18 PM
i have heard stories of a used one need to be coded and then some say no its just plug and play? any experience?
Old 05-09-2013, 07:22 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
i have heard stories of a used one need to be coded and then some say no its just plug and play? Any experience?
yes some need to be coded , it all depends on
the unit & car it came from . I have several for sale
if you need 1 & i will do the coding on it for you ...
Old 05-09-2013, 07:23 PM
BMW7_CEO's Avatar
BMW7_CEO BMW7_CEO is offline
BMW7_CEO
Mein Auto: 2005 745LI
Paper is right it's the ask Unit man you have to replace it
Old 05-09-2013, 07:24 PM
what do u charge?
Old 05-09-2013, 07:29 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
what do u charge?
I have 1 I'll let go for $250 plus shipping .
All coding included .
( I will need your VIN # to code it to the unit )
Old 05-09-2013, 07:32 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
if you have any other questions PM me your
# & I will call you .
Old 05-10-2013, 09:42 AM
anybody else have a thought?? some said "most bus". no idea what that is
Old 05-10-2013, 11:26 AM
dannyb1027 dannyb1027 is offline
Mein Auto: White 2002 745I
Listen to Paper!!!!!! The dude knows
Old 05-10-2013, 12:37 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
your NoN-working Ask is on the MOST BUS line , that is why you are having the problem .
Old 05-12-2013, 07:17 PM
if the ask is bad. can i still put a cd in and have it eject out? i did that 2-3 times. the disk never played and the screen did not turn on but i was able to put one in and it took it and i was able to eject it out. would this happen if the ask was bad??
Old 05-12-2013, 07:49 PM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
if the ask is bad. Can i still put a cd in and have it eject out? I did that 2-3 times. The disk never played and the screen did not turn on but i was able to put one in and it took it and i was able to eject it out. Would this happen if the ask was bad??
yes ...
Old 05-13-2013, 08:16 AM
ok so i unplugged the ask unit. today i start the car and the screen comes on. i can go into the climate settings and the radio area no presets or sound cause the ask is unplugged. nav area does not work. on the plug for the ask there is a little red light that blinks. i drive for 5 mins and the light stops blinking and the screen goes dead. i hit the dash and the vent area and it all comes back on for 30 seconds goes out again. does this sound like the display screen?? i dont think its the ask unit. what do u guys think??
Old 05-13-2013, 03:07 PM
Any thoughts??
Old 05-13-2013, 03:53 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
.. if you unplug anything in the loop you break the loop and nothing will work right.. if you have no idea what i am referring to you should reAd up on how the e65/6 most bus fiber optic network operates. if your ask unit is no good, send it to a repair shop or ilya; OR get a new one. last option out of all these but not least is to get a used one that works
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 05-13-2013, 04:54 PM
I did unplug the ask and the display screen worked and the I drive button worked for a bit. If u unplug one thing do they all stop working??
Old 05-13-2013, 08:57 PM
Paper??
Old 05-14-2013, 12:55 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Paper??
what ???
Old 05-14-2013, 06:33 AM
Did u read my earlier 2 posts??
Old 05-14-2013, 06:58 AM
PAPER's Avatar
CRISP & CLEAN
Mein Auto: 745LI
Re: radio,cd, display screen, and idrive
I have already told you several times
You need a new Ask . Also some 1
Already anwered you & explained you
Are still breaking the most loop .
If you want to keep playing with your
System then atleast buy a loop from
The dealer & try it between everything
To come up with some results
Old 05-14-2013, 07:24 PM
Anyone have a thought????????
  #25
Old 05-14-2013, 07:34 PM
745iguy's Avatar
we both told you what you have got to do bro. replace your ask unit or send it off to be repaired. there is no other way. there is no magical cure that will make it all work. these things are destined to fail from the factory.
PREVIOUS 2002 745i
Closed Thread
