Cooling System - Page 13 - Bimmerfest - BMW Forums
Old 01-05-2013, 10:57 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Originally Posted by wjjklj View Post
I returned the Nissens to BMA autoparts because it did not have a drain plug. They sent me a brand new BEHR that did have the plug. Maybe they changed in the last month with design but mine has the drain. If they all don't have a drain now then I would just get the Nissens because it is about $100 cheaper then the BEHR.
I have been following this post every day and it is interesting. I have also been watching my temp the last few days while driving. My car runs between 102-105. It probably say 105 more often but it does fluctuate. It has been about 35-40 degrees F where I live. I once saw 107 at idle inside my garage but have not been able to duplicate that. I wondered if it was due to lack of good airflow and it being in a confined space. I plan on checking my hose temp with INPA this weekend. What menu do I actually go in to? Thanks.
Yeah I bought a Behr from BMW a couple weeks ago and returned it.. I thought it had a drain plug.. but anyway, this one was brand new from Behr, and it doesn't so I am assuming they have done without them now..
Old 01-05-2013, 11:01 AM
Mein Auto: Nothing
So I opened the cap this morning and the expansion tank was near empty.. it seems so far the system is working correctly, it's getting all of the air out now, and running cool.. I haven't driven it long enough to tell the final idle temp, but I will let you guys know shortly.. As it stands the entire system is brand new, short the heater core and it's 3 hoses and of course the motor (Although water pumps are both brand new too).
SF: Yeah that URO pipe just looked cheap, I liked the AGA much better, and if I am going to rip the intake off and install it, I'll spend the extra money and do it once.
Old 01-05-2013, 11:40 AM
Mein Auto: Nothing
Hey SF: I fired the car again this morning and that sound is not coming from the ALT. It's absolutely coming from the intake/cooling pipe area. I can put my ear right to it and hear it's coming from there.. when I put my head near running alt I don't hear anything from it.. Is there anything in the intake area that can cause this? Paper mentioned he had heard a few people have this noise when their coolant was low, and once filled to level it went away.. this did happen the instant I drained my system for the first time..
Old 01-05-2013, 12:11 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Ok, if you think it's not alternator, not waterpump, not tensioners, so what is it??? Disa inside manifold??? It's not making this kind of noise. Remove belt and you won't hear anything.
It is you alt bc it's buried into the engine block so the sound will be heard from engine.
Want a bet???
Old 01-05-2013, 12:19 PM
Mein Auto: BMW 745i
Nah won't help,
Ok, it's gonna help: try some rain dances around like 3 times clockwise and 4 times counter, also make sure you sing that maya song))
For real get your inpa and tell us lower hose temp.
Look it's m62 engine with valley pan leak. Coolant pipe and heater core are stainless and look very nice!!! They are not aluminum crappy design which interacts with coolant chemically (hydrolysis) and kills that seals. So they knew about it in 94 at least. And they didn't want that pipe in the valley pan for a reason: if it leaks you would see it right away!
Old 01-05-2013, 12:56 PM
Mein Auto: Nothing
Okay, wait, I dance 3 times clockwise AROUND the car? Should it be running? Same with the counter? It would probably help as much as what I've done so far, certainly alot cheaper.. No, I am not sad one bit on the grand I've spent replacing this cooling system.. I know the old one is still good, so I can sell it for a couple hundred bucks.. and not feel guilty.. and the new one did improve the cooling, maybe not by much, but it does take alot longer to heat up now.. still haven't driven it enough to see if filling the expansion tank helped but I'm sure it wont..
One thing everyone should go out and check right now, is when I replaced my radiator there was a horendous amount of crap inbetween the radiator and condenser.. I mean it was loaded full of crap.. I am sure that has got to help cleaning it out.. The worst part is you'll never know it's there or see it until you take the top brace off.. it's only a few minutes to take off so I would check people!
Old 01-05-2013, 01:01 PM
Mein Auto: BMW 745i
Yeah mine was also dirty. Simply remove it, use vacuum cleaner and that's it. But still even with dirty ass radiator it still won't go higher than 105.
Last week I saw 06 750i and auxiliary fan would turn on at 101- so new DME opens up tstat even earlier.
So they knew about problems and tried to prevent it. So that's why face lifted models last longer.
Ps. Now imagine how many ppl drive their e65 with 107C thinking they are ok bc of no leaks, so they keep replacing alternators, all gaskets , trannies.
Old 01-05-2013, 01:48 PM
Mein Auto: Nothing
Could my alt be overheating and heating up everything?
Old 01-05-2013, 01:59 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Your rain dance didn't work ?
May I suggest Fairy dust or better yet
Tinkerbell herself to help solve the problem .
Sorry I couldn't resist the joking around
With you LoL
Sent from my GT-N7000 using Bimmer App
Old 01-05-2013, 02:11 PM
Mein Auto: BMW 745i
Sure it has nuclear substance inside so when it's too old it starts thermodynamic reaction which heats up not the engine only, but everything around within 5.34 mls!
Old 01-05-2013, 03:30 PM
Mein Auto: Nothing
Actually, it's funny you say that SF.. the other night I was watching some TV, and about to dose off and I got a knock at the door.. I opened the door and there was about thirty townspeople.. the plant had gone down and evidently my alternator had a capably sized reactor in it to power the town.. so I am thinking that may have sent her over the edge..
Ok, enough fun, time for the UPDATE:
I topped up the coolant as last night after filling and driving for ten minutes or so it got enough air out of the system to bring the level below the MIN by a good bit.. I filled it back to MAX, and this time I placed all the engine covers back on, just because I was tired of looking at them and I figured I would see if they helped with cooling, even though I figured they wouldn't.. System runs even better than last night.. It now runs at about 98/100 at all times.. for the first twenty minutes of driving if I start getting into start and stop traffic it will slowly go up to 105, and once there it will drop down now like usual but instead of dropping to 103, it will drop down to 99, and stay there, and drive around 99/100.. if I keep driving it will stay, if I come to a stop it goes back up to 105 slowly, and then back down to 103, and over and over.. after MUCH stopping it will stay at 105 longer and longer, before it goes back down to 103.. then it will go to 105 and stay, and then 106/107/108.. but when I start moving it goes instantly almost back down to 105..
It's def. better than last night pre-air removal, so I am hoping tomorrow morning I can get even more air out, and maybe I'll get lucky, but I doubt it, I never do.. I am thinking though, if it's not coolant pipe it may be my fan.. only thing that makes sense as to why it only heats up at slow speeds/stopped..
Also I talked to Paper on the phone the whole drive, he was driving too.. His car runs constantly around 98, and if he comes to a stop it won't go higher than 100 and it goes right back down to 99.. he checked his lower hose and it felt warm, but nowhere near the upper, so I dunno! I am lost!
Old 01-05-2013, 03:32 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
i applaud all the work you've done so far but you know the items left that you haven't replaced
either way i think we've come to an understanding that 105C isn't worth the leaky engine gaskets and seals, the jerky tranny, the tranny gaskets and seals, the alternators (for water cooled) etc - etc - etc
btw how much have you put in so far? you should be keeping track of max system capacity and what you've added, thats how you will know for sure you have a leak if all else fails visibly ;p
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 01-05-2013, 03:37 PM
Mein Auto: BMW 745i
Every time you step on gas it opens up the tstat. When it's idling DME does not open it, so you can see real way your tstat operates.
Warm or hot it depends on your skin receptors and bla bla
Connect inpa and get exact temp from lower hose.
The more you drive your car like this the more damage you make
Old 01-05-2013, 03:50 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
So what is the correct temperature? when car is not cool. normal driving.
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 01-05-2013, 03:54 PM
Mein Auto: BMW 745i
If it always stays at 105 when driving its no good.
Usually test it when idling when it's fully warmed up:
Correct way it operates
105-aux fan-103
Old 01-05-2013, 04:03 PM
rideme2's Avatar
rideme2
ok thx. cause i changed my cooling pipe for the bimmerpipe kit. water pump. and saw my temp @105c on idle drops to 100-102 when driving. so i guess its normal.
Old 01-05-2013, 04:51 PM
Mein Auto: BMW 745i
Does it drop when idling or when standing in traffic to 103 with aux fan on??
Old 01-05-2013, 04:57 PM
rideme2's Avatar
rideme2
when i'm at a light it goes to 105 if just light to light local driving it drops to 103. if i get on the park way it drops to 100-102.
Old 01-05-2013, 05:01 PM
Mein Auto: BMW 745i
Usually 750 won't go higher than 102C, even if I drive it rough and stop and goish and it never showed me 105. But as long as it is 100-102 when idling is good enough.
Old 01-05-2013, 05:02 PM
rideme2's Avatar
rideme2
do i need to bleed the system? if so how?
Old 01-05-2013, 07:36 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
105-aux fan-103
Ok I just got home from a decent drive. The car stayed between 102-105. When I got home at idle it went to 107. I hooked up INPA and here are the screen shots. Bottom hose readings are not consistent. What does this mean? Internal leak? Need coolant AGA pipe? Thanks for looking at this. All hoses, water pump, thermostat, and radiator replaced in the last 2 months.
ID:	356159   Click image for larger version
ID:	356161   Click image for larger version
Old 01-05-2013, 07:38 PM
wjjklj's Avatar
One more picture
Old 01-05-2013, 08:14 PM
Mein Auto: BMW 745i
One more picture
Welcome to the club!!!!
It's bad. 30C is cold. You need aga ASAP.
Also your MAF is prob dirty bc it uses too much air, should be around 13-14 when idling.
Old 01-05-2013, 08:15 PM
Mein Auto: Nothing
So it looks like we are in the exact same spot.. Driving I am between 101-105 and if I idle for too long (not long at all) it will go to 107.. It seems like when your tstat is around 105 and opening your lower hose temp of 69 is good.. then when the car gets hotter and goes up the lower hose goes down, as I am guessing it's not opening.. so if they designed the fan to go on by the lower hose then this system falls apart when whatever is causing this issue to happen happens..
EDIT: May I ask why you replaced your entire cooling system too? How did you bleed coolant? Are you losing any coolant? What is your level at now?
For the guy who asked what I have spent, I am right around 1 grand so far.. None of it seemed to be bad, but the new stuff def. runs cooler, and more flow.. so as soon as I figure out my issue I believe it will run great.. plus now I can sell my old cooling system and know it's fine.. Also, at one grand that is all wholesale prices.. Radiator is $400-something I paid $250 out the door, hoses were $175, I paid $78, and so on.. thermostat was $100 I paid $55.. so at retail I would have probably spent near two grand.
Old 01-05-2013, 08:17 PM
Mein Auto: BMW 745i
No, no need it should bleed itself,
Connect inpa and check lower hose temp after 20-30mins idling after driving.
If it stays at 65-70C it's all good.
