7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#326
If lower hose temp is dropping when idling it means that tstat isn't working at all. And now you believe me that wheep hole leak is not the only symptom of the leaking seal!!! I should make a contract with aga pipe so I brought them much more clients! |
#327
I just went for a 30 mile drive on the freeway.. after driving for a few minutes non stop the car cools down to 101/102 and goes to 105, and back down, over and over.. does it the entire time, after a while it just stays at 101 the whole time.. when I get off the freeway, the 105 stays at 105 much longer, but will drop down to 103 eventually.. if I come to a stop for more than 45 seconds or so it will go to 106/107.. With the new cooling system when I start the car cold now it takes a good 15 minutes to get to normal temp.. runs around 98c or so for then.. slowly the system seems to be overpowered by heat.. the old system did the same, but much quicker.. I wish I had another good running car I could swap the fan on and see what happens..
#328
Better start rain dancing You don't need to think about aux fan at all. Simply even without aux fan temp will never go higher than 105 if everything is ok with system. Start removing intake and valley pan. If you're lucky you can fix the pipe without removing wp. With URO pipe I was able to fully fix the problem but that pipe lasted for 3-4 months. Your pipe is leaking into valley pan for now, later you'll get wheep hole leak and all other leaks. If you don't want to understand this theory simply do the pipe job just for maintenance reasons and you'll notice that problem will get fixed on its own. It's simple: Coolant pipe is the main coolant supply to the heads. Valley pan is a return to WP. Now imagine you have a leak from coolant pipe into valley pan. You got it??? Cooling system efficiency drops significantly, and more importantly it creates cavitation- your lovely bubbles Yeah I was kinda cheap with URO, but they promised the best quality, and think about it AGA didn't have any parts history, but URO parts is kinda reputable company with history. Last edited by SFbay; 01-05-2013 at 08:36 PM. |
#330
Why is the temp not consistent? It is like 69 in one photo? Leaking coolant pipe? I have no leaking out of weep hole. Are you saying it is leaking inside the valley pan right now and is just not bad enough to leak out weep hole?
My take on the theory is it's leaking out of pipe into valley pan, but valley pan is sealed.. that loud noise I get when I start my car: SF says 200% it's my alt. and I will take his word on that, with 200%, but before I knew that my first thought was "Okay, if it is coolant pipe, maybe that noise is all the coolant being sucked back into the pipe from valley pan"
#333
#335
And it's not a theory, I personally removed waterpump, sticked my finger and inspected the seal, it was missing a chunk of rubber on the bottom and small teardrops were coming from this hole even though I cleaned the pipe with towels so it was dry inside but coolant was coming only from that front seal, which means it was coming from valley pan but very slowly like one drop per 10 seconds smth, imagine when engine is hot and pressurized! |
#336
I just replaced mine lastnight.. I bought the Behr, which now has no drain plug like the Nissens. Sorry, I just noticed you said alt.. Yes, I guess I will be buying one.
#337
You're risking to screw your alt when driving like this, it might get your engine stuck in the middle of the road. When everyone here fixes the internal pipe leak, you owe me a box of Heineken beer for all my research and experience Also if we buy 10-20 aga pipes we can get very nice discount!!!! I'm in Last edited by SFbay; 01-05-2013 at 09:19 PM. |
#338
Ok, 2 pipes. May be let's create a thread so everybody with 7+ yrs old or 90+ miles needs new pipe to save engine and tranny and further money wasting.
#340
I'm on the list I am going to get the AGA pipe. I will volunteer to contact them and see how many we have to purchase to get a discounted price. SFBay if you want to do this instead since you started the thread and live in the same state as AGA that would be fine to. I guarantee there are many others here that need to do this if they just check their temp in the hidden menu and then if high check bottom hose temp with INPA.
I contacted Martin at AGA via email asking for a discount and how many member purchases we need to receive it. SFbay, you get all the credit here, I'm just trying to contribute. I'll keep everyone posted.
http://bimmerpipe.com/
Kinda looks nice and they claim that rolled piece if metal is the key to reduce electrolysis, aga pipe doesn't have it. |
#344
I also have that gurgling sound only happens after car has been driven for awhile then you only hear it when at idle eithet park or in drive not moving. I brought it to dealer for that sound couple times and they told me it was cylinder head cover on passanger side. Not sure if i believe that though.
#345
I replaced my pipe and pump two months ago. I tested the temp while driving yesterday. I got 105 to 108 sitting at the light after a highway drive home from work about a 20 min drive. I was hitting the car pretty hard on the freeway in 3rd gear and about 4500 to 5000 rpm before shifting into 4th.
Car would cool at the higher speeds down to 98-103.
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#346
What brand you installed?? Btw you installed it yourself??? Did you have problems installing the new seal??? For me it was a disaster, it didn't want to sit nicely no matter what I tried to clean that groove. Last edited by SFbay; 01-05-2013 at 10:37 PM. |
#347
I went with the AGA pipe because it has a threaded connection vs the bimmer pipe just twisting in place. I felt that the bimmer pipe could come back apart. I did go with the BMW water pump as my Indy stated that the other pump was made in china and he had problems with them before. Realistically you could get all parts needed for under 600.00 with the bimmer pipe and non OEM pump. I will check INPA on the lower hose tomorrow If I get the chance.
#348
Hmm smth is telling me that oem pipe is much better than any of these collapsible pipes, at least it lasts 60-70 mls. Why they say you need to remove heads?? It seems like only lower timing cover has to be removed. Last edited by SFbay; 01-05-2013 at 11:00 PM. |
#349
Anyway, I know you are idling at same temps and you just replaced your pipe which would rule the pipe out.. I am wondering this: Could replacing the pipe put the system back up to correct pressure and then blow rear seal that requires trans to be removed? I know removing the trans is supposed to be much easier than the coolant pipe job but not for me, as I would prefer working on the ground in my garage on my time.. This leaves us only a few other things to be causing this: Head gaskets? Everyone I've asked so far on this has either laughed at me or said hell no, but it sounds very plausible to me.. tho I don't have bubbles or oil/coolant mixing.. Heater core? Probably the biggest pain in the arse job of all.. Again, no leaking of coolant, I do get a smell sometimes when turning on, but it's clearly a dusty smell.. Heater hoses? The only pipes with coolant going thru them that I haven't replaced are the two hoses going from the heater valve which the aux water pump goes into, and the third one which is the return pipe from core to engine.. Electric fan? This is a big one, I believe this to be the problem, but I am not certain.. if it was un-needed there wouldn't be a fan on every car ever made right? My cooling system seems to run great, but it slowly looses it's battle with heat when in stop and go.. always moving and the cooling system is always happy. Heater valve? This may be completely unrelated but, when I turn my car off for a while, even after not using the heater for weeks before, and come back to it and start I will get heat from the vents for a couple minutes.. I was told this sometimes happens when battery is going bad, and mine was, but when I replaced with the brand new one and programmed every issue went away, but this remained.. Could these valves or a vacuum line somewhere be the cause of this? Could they be letting air in? I don't quite know how these things operate, obviously just electric valves, but I am wondering if they could be letting air in without letting coolant out.. Other than these reasons we are left with the engine.. Either seals in the engine, or generating too much heat, or something.. I need everyone's help to brainstorm! Please start thinking! Collect data! I have been collecting data since the day I realized this car was running hot, and it's a help. You can rule a lot of things out when you are making an informed decision. |
#350
Yes this is what I'm scared:
You fix one leak and you get another one!!!! This is how it happened in my car: Had lower radiator leak for months and all was good except loosing coolant. Once I replaced radiator 1-2 months later I got coolant pipe leak!!! The pressure is fking high in this car: Any weak spot will tell about itself May be URO parts is not that bad and once it got fixed the rear plate started leaking;( In other words you need to replace all cooling parts in the engine: Coolant pipe seals Rear cover plate Valley pan I think this is my plan: Install 85C tstat or keep 95 one, but 95 is still kinda hot. Replace coolant pipe Since pressure won't be that high the other rear seals should sustain it. Honestly bmw should recall that ****ty design!!! Last edited by SFbay; 01-05-2013 at 11:30 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
