7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#51
I noticed something the other night.. when I was on the freeway, and I gunned it, and really wound it out, it went from 103 to 92 instantly.. so that tstat can really open if the DME wants it to.. I wonder if the Alpina tstat is lower?
#52
this was right after a highway run and some city driving, taken right after i parked.
no i actually didnt replace heater hoses, nothing after that duo valve, only things i didnt replace
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
#53
ps wth is that 6 degree thing? that cannot possibly be correct.
#54
Thats what I was wondering.. couldn't mean radiator cools it down to that low..
#55
I removed tstat and it's equal to full open mode almost so my temp never went higher than 66! while driving. Also tstat will open on its own when you keep high rpms: even with air in the system it will open tstat bc of too much flow. Last edited by SFbay; 12-26-2012 at 11:10 PM. |
#56
Hey SFBay did you read my post RE Alpina? Whatcha think?
#57
Final stage testing
Opens up at 95-96 |
#58
This has probably been the most informative thread in this section for a long time and i haven't seen much response to it. It amazes me that the truth about important info with these cars' weak points doesn't get half the attention that aesthetic modifications get.
Then yet based off all of these i have seen for sale on CL hell even on cars.com etc i have noticed lots of little red cars on the mmi and a little engine shape on lots of kombis in their pictures. I guess owning a pretty car is more important than owning A car that is both aesthetically acceptable and fully functional?
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 12-27-2012 at 12:57 PM. |
#59
That's weird that 3 months ago nobody even showed a little interest for it, but now looks like ppl realized that e65 is not only about wheels Gonna install modded tstat soon!!! Should be no more than 96C before fan kicks in!!! Cross your fingers I'm 200% sure all those leaks are related to high temp, otherwise e65 would cost much more than kbb says today! Last edited by SFbay; 12-27-2012 at 01:09 PM. |
#60
Good luck this is definitely a mod that should be deemed necessary by e65 owners, i never even knew that the car ran that hot until i saw these threads and been watching them. My e420 4.2 v8 and c320 3.2 v6 didnt run anywhere near that hot and they let you watch the engine temp in the instr cluster
#61
Nice man, still not clear on the entire process here. How did you work out the heating element for the DME? Did you transplant a thermostat to the old housing? If so how many modifications required? Am wondering if we will get any underheating warnings or something similar.
#62
Heating element was completely removed, otherwise it wouldn't fit. There would be no warnings bc I installed the resistor for the DME. |
#63
Great!when do we get the DIY!!lol!SFbay are you gonna market this or can we have the plans for free
![]() Sent from my M975 using Bimmer App |
#64
But I'm still thinking there might be some very small leak in my engine and bc temp is not that high anymore coolant is not boiling inside letting tstat to open. I'm assuming it's leaking from that rear engine plate, where you need to remove tranny to replace!!! Bc my mechanic found some small tears coming from bell housing and it was coolant;( At least it's not overheating anymore and temp is nice! Just like in 6 inline Last edited by SFbay; 12-27-2012 at 03:33 PM. |
#65
Good work sfbay you could be a bussy man if all the testing goes well. This should be a sticky or diy.
#66
this time i took the screen with the engine running. this makes much more sense after highway driving, some city, and then idling for 10 minutes while i brought in some groceries
but i wonder if my tstat is different because my DME coding
#67
#68
This one is correct! This is how it should be 66 lower hose. But mine was 102-103 and lower 66 This is what I realized: Just bc of very high tstat temp 105C lots of orings get flattened and even small sipping will cause pressure loss and if cooling system is not getting enough pressure the coolant inside will start boiling causing tstat not to open!! So now it's not getting to 100C so even if my car has some small leak its not getting to boiling point. So... If your car gets to 107C and aux fan is not doing anything- you've got some leak very tiny, but enough to screw everything;( Last edited by SFbay; 12-27-2012 at 04:55 PM. |
#69
#70
So the screenshot was done when idling or not?? If not it explains why 92. Try checking it after driving for a while and in traffic when idling without heater and make a screenshot.
#71
after driving a few miles on the highway, then city traffic and then taken while i was idling parked after i brought in groceries and before i went inside for good. heat was off
#72
the first thing i posted with the 6 degrees and 101.25 was with the car off and it didnt seem right, drove then idled and thats what it reads, when i shut the car and look with ignition on and car off the readings are higher on coolant temp and much too low on output temp
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 12-27-2012 at 08:44 PM. |
#73
So this is after driving freeway, and town, and traffic? 92c? See that's what I don't understand.. either your TSTAT is bad, your DME is opening the tstat way early because of a sensor or something, or your car is running super cool from the small coolant loop and not even using the lower radiator hose.. I don't understand how this could be.. only thing I can think sounds right, is either DME is opening it early, or do you happen to have an 02? I heard somewhere that the early 02's got a 92c tstat.. Or I should say the early N62 engines.
#74
Thats correct
My 02 according to vin is 07/02 but i dont know about the early n62 thing personally
#75
Also no tstat error code.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 12-27-2012 at 08:26 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
