7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#851
Why didn't you clean air passages at the same time?? |
#852
SFbay you still going to sell us some 95c tstat man!
#853
At 147k by now i would bet id have a serious prob by now
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
#854
Yep and once you're there replace valley pan and coolant pipe
#856
Exactly what I'm going to do.. going to go with the AGA pipe in a week or two.. Will hope and pray my rear plate isn't bad but I am sure it will be..
And if it isn't it will shortly after.. |
#857
Fixed leaking valley pan and it blew rear cover What a great car!! I think either my foot is too heavy or my mpg is low?? 14-15mpg city;((( oh well it's 4,4 anyways |
#858
Jees i wish i get like 12 in my city. Ive just always thought crappy gas or the fact there is a stop sign or lights at every intersection.
#859
Also replaced rubber boot from tb to maf, they have redesigned it, and I think it seals better, so it revs nicer |
#860
#861
SF, got a part# for that boot?
'11 328i '03 745Li '03 Acura TL-S '02 Infiniti QX4 |
#862
Just a boot, it has small plastic hose sticking out, mine was weak.
http://www.rmeuropean.com/ZoomImage....2_GEN_E095124A |
#863
oh that... ok thanks.
#864
Hey SF, any news on the tstats? Also, how hard was it to drop your trans? I am wondering if I can do myself and replace that plate..
#865
Before removing tranny check for any signs of leaks between tranny and engine. |
#866
But I was messing with the coolant mixture again, so I will have to go back to the last mixture.
#867
And it's not summer yet. Do the pipe and you'll thank me! Once again you listen to aga folks who say if no leak no pipe problem, right?? But it is, remove your wp and dry the pipe inside and you'll see water coming out from the cooling pipe, which only means its coming from valley pan, bc it full and you cannot drain it lower than those water channels. This leak at high temp will greatly reduce water pressure- therefore valley pan return won't be able to open tstat. Last edited by SFbay; 02-14-2013 at 09:34 PM. |
#868
Hey cmpcpro what mix were you using at 110c.Ive found 60 water 40 antifreeze is working great for me.Temps here have been down to single digits up to 70f and my engine temps have worked our well.Yep here in Ky we have wild climate changes sometimes day to day.I also took engine cover off after reading e46 guys do this a lot.Dosnt really bring coolant temps down but they say it lowered oil temps by 10 to 20.
#869
Has any member here tried the "Evans Coolant" and if so what has been there results, real world. Just asking cause it looks interesting.
thanks
Not yet, I have been wanting to try it but I don't know how to get ALL the water out of this system.. with the water cooled alternator, aux pump, etc.
#872
Drain the block the rad and flush with the Evans prep. As long as you get under 15% iirc from their website, you should be good. Comes with test strips i believe; to see. Or you can empty some again after filling to dilute and refill but with Evans that will get costly.
#873
Read about Evans crp and you'll find out that it keeps your engine hotter than regular coolant. No pressure, but cooling sucks |
#874
i wasnt suggesting it would fix the leak, was just explaining what to do is all if he wanted to try it....
#875
It wont matter to me either way. I think my insurance is going to total my car by the way the adjuster was talking to me about the car... and if they dont Im going to sell it because i definitely dont want one of these after an accident going 60mph and spinning. Nemo got me
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
