7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#176
And this has always been in relation to a hot block and heat over time.
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#177
Wow Great read everyone who added Info to this thread. Possible new Member here. Might be pulling the Trigger on a 03 745LI with 41,000 miles....
I live in modesto so i will be Definately doing your MOD with you SFbay Just give me the $$$
#178
hey! I know what we can do! Lets stick a pipe through the valley that is held on by a rubber o-ring gasket that cannot withstand the cars normal operating temperature! Must of been to get more maintenance and warranty work That same guy must have said hey lets have a bracket for the alternator over a passage that is only used for vehicles with the specific oil cooled version and the ones that are not lets take that same rubber and seal it up with that! Ive said it a lot i love the car, my car isnt even causing me any trouble at the moment (yet) when i am done with this one though, i will probably stick with MB. If i do ever decide to buy a bmw again, will probably not be a v8. If you look through the f01/2 forum some people are having these same types of issues. Even reading a few reviews of the newer bodies people were complaining about jerky transmissions. Time will tell if they suffer the same fate as the e65/6 Bmw clearly dont care and openly dismisses these issues as normal. What happened to cars that can stand the test of time?
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
#179
Well the car sat overnight and I opened the cap and got air pressure, so I know it's bleeding, perhaps I just need to be patient and wait a few days for it to get the air out.. I think opening it when it's hot and squeezing on the upper hose is just adding more air.. I drained the expansion tank again, this time I was in my garage so I caught it in a bucket.. after all the draining and filling with water yesterday, it still looked dark blue, like it was all coolant.. this stuff is really concentrated evidently.. I will start it soon and let it mix again, and I wouldn't be surprised if it will be dark blue again.. I don't know about this coolant, I think your right SF, it's either junk, or the best, because it's really thick and goopey.. I don't know if that's good or bad, but I can tell you just pumping it out of the expansion tank it was bubbling up everywhere, so I really think it is either the cause or a big help with all these bubbles.
#180
my 99 c230 benz (4cyl 2.3 DOHC supercharged) stays at 90C :P damn BMW! these little devils having a motor running at 105 :O SFBay is right they designed it this way to create problems , or it seems that way!!!!
#181
Hey cmpcpro Ive noticed a couple of behaviors that may be same symptoms youve already encountered.When I pull up at home (now winter)car is idling 500 rpm no matter the climate setting.30 sec of idling temp goes to 107c ,fan comes on and temps stay the same.If i do the same thing and give it the gas at idle(stopped)to 750 rpm the temps set at 105c rock solid.Does this mean not enough flow at 500 rpm?I used 750 rpm because Ive noticed it idles at this speed in the summer.Oh and I always have the A/C on.
#182
Hey SFbay I put my key to 2cd position after reaching 107c engine off.Listening to aux pump for the first min.it ran smooth but after that not much noise but would jump a little every 10 sec or so.
#183
That means you too have air or "bubbles" in your system.. same issue.. I shut the car off today at 107 and popped the hood and losened the sensor on the top of the water pump and got air/water coming out.. it may have just been presurized air and if I keep doing that it will escape, but to me it may be boiling.. problem is, even with 50/50 coolant mix (BMW) it's actualy either the same or even worse.. I am at a loss as to where to go next.. I don't understand why I am getting this horrible groaning noise again even with a brand new water pump.. I bought a new tensioner today which I will install tonight, but I don't believe it's the issue.. The bearing on the old pump seemed fine.. I don't believe they should require water to run correctly, although I may be wrong.. but something is making noise when cold, and it's loud enough that I am afraid to look under the hood when it's happening in fear it will let loose and kill me.
#184
Valley pan will fix it!! Hope you're not mad at me I had my first e65: had the same issue with 107-110C!!!! Then I decided my wheep hole was bad, though it wasn't leaking: I replaced everything and temp came back to 103-105, the problem is after 4 months I got that problem again;( Valley pan had visible leak from rear bolts. Could be steering pump as well Or just tensioner- simply spray some wd40 and start it. Ps. Happy new year to everyone!! Last edited by SFbay; 12-31-2012 at 06:07 PM. |
#185
I'm not mad at you SF, I am very appreciative that your here.. I think I did take out too much coolant, as it is def. boiling when I crack the sensor on the water pump.. I will put back the coolant, but it seemed to run better with more water.. so I am lost.. I am going to replace the one line I forgot, which goes from water pump to trans tstat, and then I am going to replace the hose from the aux water pump to the heater block.. that's it.. I would love to get the info on your tstat, as I believe my issue is a breech when I hit such a high pressure, I believe seeing as I am losing no coolant that dropping the temp would infact solve my issue, while I know it isn't a correct "fix".. I have to think that BMW installing a fail safe for just 3deg higher than normal temp means they expected this issue to arise, so I would love to be able to get a 95c tstat in there.. otherwise my next move I think should be checking out that Evans NPG+.. thinking that will atleast drop pressure to near 0, and will solve the boiling issue.
#186
Nope, it's incorrect:
First you need to fix the system, then improve it. I'll be replacing the valley pan next week so I'm suggesting you the same, there is no workaround when it's bad already, the leak is very small but it does exist when heated up. It's like that British joke: Two hunters: -Do you see a rabbit??? - nope, sir!! -neither do I, but it's somewhere here for sure Last edited by SFbay; 12-31-2012 at 07:43 PM. |
#187
I tried going more water then coolant and it was def. boiling.. so now I am going to add more coolant than water.. I know you keep saying leak, but can there really be a leak with absolutely no coolant loss? Also, I talked to a guy who builds BMW race engines, not sure how new of the cars he works on but when I told him that it runs wonderful when moving and goes up only at idle the first thing he said was, it sounds like your fan isn't coming on correctly.. When my fan does come on, it's not very hard and it seems to go back off very quickly.. can these fans be rebuilt? What do you think about that SF?
#189
Yep cmpcpro I don't like the fan operation either.Im still stuck on 250 more rpm at idle and temps are 105c solid.Even drop back down to 500 rpm and temp never goes back up.105c solid from then on??WTF?
#190
Hey SF: I hate to keep asking, but I would love to get my hands on the specs or what you used for the 95c stat.. willing to do whatever you think is fair, but I am not losing any coolant, so I wouldn't mind trying that, even if I still have an issue, I would like to atleast start on the stat, as I will probably solve problem by then. Thanks. Last edited by cmpcpro; 12-31-2012 at 09:47 PM. |
#191
The fan could certainly be the key.. car runs right, tstat opens great, car will actually run great down to 102 or so and stay there.. then when coming to a stop you can tell it's like slowly loosing the battle.. slowly it goes up, up, and bam boiling and up in temp.. if you drive around again for a while starts opening again and gets cooler, meaning no longer boiling... Either have a leak somewhere that is so minute it's just sucking air in and no water out, or radiator issue or fan issue.. I wonder if the alt. could be going out and cooking the coolant? Going to start adding more coolant.. it seemed like less was better, but the last time when I filled the brand new cooling system I got close to 50/50 but still more water, and it seemed worse, sometimes tstat wouldn't even open moving, but it could have just been air in the new system... I didn't give it time.. I will buy one more bottle (my third one at $20 each) and start adding more to see if it gets better or worse.. On Wed I am picking up the last hose for cooling system and the heater hose.. besides radiator that is entire cooling system short motor/heater.
#192
The leak thing kind confuses me because this system is under so much pressure.It would have to suck the air while cooling off after shutting down.If this was the case it wouldnt it self bleed once driving and heating up and high pressure again?,Just seems hard to believe a leak that small would raise temps that much.
Sent from my M975 using Bimmer App Last edited by dolfan13; 12-31-2012 at 11:16 PM. |
#193
i guess im in between 146k
no leaks atm but i want to do this asa i can. i think i will have this for much longer if i do this tstat w/ npg w/ no leaks currently
#195
Ok, guys calm down:
I had 3 e65s already within 5 yrs. All of them had similar cooling issues: - fan is totally functional and has nothing to do with it - fan won't kick in just bc lower hose is not that hot enough less than 65C. Btw The racing guy knows nothing about engines The lowest miles e65 had 87k miles And same fking problem, so I fixed tranny and sold it. Only 160k miles was doing okay, but not for long;( Leak can be very small and will take time to notice but enough to not bleed the system. Or only bmw coolant can sustain that crazy heat? Idk I'll try for some fun bmw coolant and oem tstat, but I definitely have a leak. Did anyone try any other coolant than bmw one?? |
#196
Also update on groaning noise: I replaced the top tensioner next to water pump.. when it was warm it sounded fine, now that it's cooled off and I spin it I have a vibration and it makes a slight noise, so hoping that was it.. which means my water pump with 50k on it was fine.. lol
#197
Anyhow don't worry even with pure water it should not boil, so the answer is damn leak with air fking pockets!!!! The pressure cap on a cooling system is the key to raising the boiling point of the 50/50 mix of antifreeze and distilled water. For every pound of pressure cap rating the boiling of point of the above mixture raises 3 degrees. If you had plain water in your cooling system with a 15 pound pressure cap the water would boil @ 257 degrees. If you had a 50/50 mix of antifreeze and water the coolant would boil @ 265 degrees with a 15 pound cap. The boiling point would raise to 270 degrees if you had a 60% antifreeze mixture with a 15 pound cap. If you had a 70% mixture the boiling point would raise to 276 drgrees. So..... Fix the leak |
#198
Well took off the cap tonight after car cooled off completely.. Coolant went from a little above max to below min.. so seems like it may have got some serious air out.. Will drive it tomorrow.
#200
It's 2013 and your car is 10yrs old already I'm not getting why don't you try what I told you from very brginning??? Valves are good if it blows hot air. -bypass heater core -replace valley pan Last edited by SFbay; 01-01-2013 at 08:11 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
