Old 12-25-2012, 03:41 PM
idofgrahf idofgrahf is offline
Mein Auto: 540i 2001
645ci 2005
Hi, a quick question for you guys, whats the approximate cost of replacing a transmission on a 645ci 2005 (automatic)? I have the opportunity to buy one for cheap but the transmission is out. Thanks.
Old 12-25-2012, 04:36 PM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
The stupid dealership told me 6,200 but someone on this site told me how to reset my Transmision and it worked.
Old 12-25-2012, 05:51 PM
how do you reset the transmission? could you please provide the link for that post/faq? Thanks.
Old 12-25-2012, 07:21 PM
HerbP HerbP is offline
Most of the time a dealer says the transmission needs to be replaced, they don't know how, or want to fix it. If you had a dealer replace the tranny, I thought I heard 12k!. I would want to see a sample of the fluid before I took the chance of buying it with problems. Have a sample of the fluid tested, then make a good decision. If the current seller changes the fluid & filter before you buy it, the problems might disappear. Then the price would most likely increase dramatically!
It's a tough call without the correct information!
Good Luck!
Old 12-26-2012, 05:12 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
Dealers do not actually repair broken transmissions, much easier for them to replace and send back to BMW or whoever to repair. It is much the same with engines, so they cost it accordingly....
Always said I would go back to a 6 series
Old 12-26-2012, 06:19 AM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
You may want to look into replacing the transmission solenoids in the Mechatronics unit. Very seldomly does an entire transmission need replacement. There is a write-up about this on the bimmerforums. The beauty of it is that you will only spend roughly 500 dollars for the replacement solenoids and a little bit of your time rather than the 6500 dollars that the stealership is attempting to scam you out of. Here is the link:
http://www.bimmerfest.com/forums/sho...d.php?t=654634
SEMPER FIDELIS
Old 12-29-2012, 08:06 AM
CJ645Bern's Avatar
CJ645Bern CJ645Bern is offline
youtube.com/lidlgangsta
Mein Auto: 05' 645ci & 01' z3
I believe it's even you turn the ignition with the engine still off you step on the gas for 60 seconds
Sent from my SAMSUNG-SGH-I747 using Bimmer App
live fast, drive faster
2010 Acura TL (daily driver)
2005 BMW 645ci Coupe (traded for TL)
2001 BMW z3 3.0i vert' (TOTALED RIP)
1991 NISSAN 300zx 2+2 (gave to brother)
2007 BMW z4 (traded for 6er)
