Old 12-26-2012, 09:34 AM
htmnc htmnc is offline
Mein Auto: Z3
1996 Z3 Roadster - Start Up Squeek
When I start up my Z3 when it has become cold (such as overnight) it makes a squeek sound like a belt that has to warm up and then stop making noise. It lasts about three minutes.
My mechanic has noted that it is time for a new timing chain (or belt???) and a radiator flush. Could this be the cause?
It is not a crazy, insanely loud sound, just sort of high pitched whirring.
Old 12-26-2012, 01:08 PM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Belts can squeak. Get a tube of belt dressing and dab some on the belts - it will spread itself around. I don't like the spray dressings because only a little gets on the belt.
If the belts are still 1996, they should be changed.
The timing chain is permanent, internal, oil-lubricated and does not squeak.
Flushing the radiator will have no effect on the noise.
Old 12-26-2012, 01:21 PM
crappyattitude1 crappyattitude1 is offline
YYZED3M Driver
Mein Auto: '99 ////M Roadster
Could be.....
Tensioner (idler) pulley bearings.....
Crappy : )
(Just outside of Nashville)
Old 12-26-2012, 01:27 PM
vintage42's Avatar
BMW CCA 1405
^^ and new belts.
Old 12-27-2012, 01:38 AM
Bellarose Bellarose is offline
Account closed at users request
Mein Auto: BMW 2001 Z3 2.5 I
Had the same problem -- 2001 Z3 with 13,500 miles. I changed the belts and squeaking stopped.
Old 12-27-2012, 06:40 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Additionally, if you are having belt issues, it could be an indication that they are original and need to be replaced. That's also an indication that the cooling system has not been replaced. After about 80,000 miles, the plastic pieces in these cooling systems becomes brittle, can break catastrophically, and quickly ruin an engine.
It may be time for a complete cooling system replacement including: belts, hoses, water pump, radiator, coolant reservoir, thermostat, thermostat housing, and if it's a 1.9: two more plastic pieces on the engine.
If that has been done, I would consider idler pulleys. A mechanic can usually quickly isolate the noise using a piece of hose or stethoscope.
Old 12-27-2012, 10:45 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
If your mechanic is telling you to replace the timing chain due to age, find a new mechanic.
BMW has not used timing belts for MANY years.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-27-2012, 01:09 PM
vintage42's Avatar
BMW CCA 1405
But before he changes belts, a dab of belt dressing might be worth trying.
Old 12-29-2012, 11:47 AM
ALM168 ALM168 is offline
Mein Auto: Z3, e46, Ford Explorer
Standard wisdom says not to spray belt dressing on serpentine belts (check the warning on the can). You might try spraying pain old water on the belt to see if this quiets it down. If it does, then you need to replace your belt(s). I had some temporary relief on a squeaking belt on a non-BMW car by putting some Comet cleaner on the belt. It removed the glaze from the belt...but in end, the belt needed to be changed.
Old 12-30-2012, 01:10 AM
I was very lucky with a rare find 2001 z3 2.5 with 13,500 miles. show room condition. Belts squeak -- with car being 11 years old I replaced belts, battery, oil. She runs great !!
Old 12-30-2012, 04:26 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by ALM168 View Post
Standard wisdom says not to spray belt dressing on serpentine belts (check the warning on the can)....you might try spraying pain old water on the belt to see if this quiets it down.
I always use the dressing in a tube, put a dab on a finger tip, and rub a little of that here and there on the accessible sections of the belts. That's all it takes. I would not spray belt dressing because most of it gets all over the engine with very little getting on the undersides of the belts. I think water might momentarily quiet a belt. But if the belt is slipping, the lasting adhesion of dressing is needed rather than the temporary lubrication of water.
Dressing is a stop-gap measure to quiet noise from a loose or misaligned or worn belt. The condition causing the noise needs to be addressed sooner or later.
