97 z3 1.9 knock senser
where is this thing located if im standing in front of the vehicle... 2 codes 325 330 both leadind to knock senser
There's two knock sensors, both on the driver's side of the engine block under the intake manifold.
#18 is the sensor wire:
can i get to these without pulling the intake back off?
I've only heard rumors of people doing that. The sensors need to be torqued down to a specific value and you should keep their orientation the same as the factory install. Would be very tough to do that with the intake installed.
wholy **** this car just keeps getting more interesting
The Bentley Manual page 113-16 says the upper intake manifold must be removed to replace the knock sensors (two on one harness). The upper manifold unbolts from the lower manifold, which remains on the head. You can download the manual. Google Bentley_BMW_3-Series_Service_Manual_(e36) and there will be several sites offering it free.
EDIT: Better search for bentley bmw 3-series _service_manual(e36).pdf Here's the sensor: http://www.pelicanparts.com/cgi-bin/...31%2E%39%20%20 and http://www.***************/1997bmwz3knocksensor.htm Anyway, go to car-stuff dot com and search for 1997bmwz3knocksensor Here's some threads on it: http://forums.bimmerforums.com/forum....php?t=1465904 and http://forums.bimmerforums.com/forum....php?t=1846765 Last edited by vintage42; 12-30-2012 at 05:21 AM. Reason: URL blocked. Need to add .pdf to find downloadable file. |
And here's the upper manifold removed: http://www.318ti.org/forum/showpost....24&postcount=2 Last edited by vintage42; 12-30-2012 at 11:27 AM. |
