Old 11-10-2016, 10:53 AM
Q4's Avatar
Q4 Q4 is offline
Mein Auto: 2008 x3
N52 ngk spark plugs
Just received 6 new BMW branded ngk spark plugs from getbmwparts.com.
Three questions.
1. Everything I have read says that the plugs should be gapped correctly from the box however the gaps look quite large to me. Thoughts?
2. The Bentley manual and everywhere else says to torque the plugs to 23+/- 3 NM. However the spark plug box says 30NM +/-3. What to do?
3. Have also read not to use copper grease or anti seize on NGK plugs. Is this correct?
Tim
Cincinnati
Old 11-10-2016, 10:54 AM
Q4's Avatar
Q4 Q4 is offline
Mein Auto: 2008 x3
Pic of box torque specs
Tim
Cincinnati
Old 11-10-2016, 11:02 AM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
I would stick to the Bentley torque specs. That's a pretty typical value. I don't have in front of me what the actual gap is supposed to be, but the gap is quite large so I assume it is correct, particularly if they are all similar.
Old 11-10-2016, 03:37 PM
DangermouseX3 DangermouseX3 is offline
Mein Auto: 2007 X3, 2008 X3
No anti-seize on NGKs
Have you measured the gap? What is it?
Old 11-10-2016, 08:27 PM
mtbrdad mtbrdad is offline
Mein Auto: 2007 X3.0si
Three questions.
My experience changing the spark plugs, http://www.bimmerfest.com/forums/sho...d.php?t=818362. If I recall correctly the gap of the new plugs out of the box was .043" and the ones I pulled out were at about .063". I just torqued them without grease.
Old 11-10-2016, 11:56 PM
dukedkt442 dukedkt442 is offline
Mein Auto: 08 E83; '86 442; 84 GMC
N52 ngk spark plugs
If they're iridium/tipped, they can't be gapped with a traditional gapper because the tip gets damaged.
Torque to the head's spec listed in the Bentley. Even so, really feel it; aluminum is SOFT.
Ive never used anti-seize on plugs, but with the electrolysis that occurs from different metals, it probably wouldn't be a bad idea unless the plugs specifically say not to (for grounding purposes). Changing plugs have been known to pull the threads right out of the aluminum heads on Fords quite often.
Old 11-11-2016, 07:39 AM
a little lubricant and thread info
Three questions.
Don't use any grease or anti seize on a spark plug threads unless the plug or manufacturer repair manual actually call out for it. If the OEM plugs torque value was calculated without lubricant adding anti seize lubricant to a plug would lower it's listed torque value. As an example here's an ASTM data sheet regarding torque values for screws and it has different columns with or without lubricant and how it affects the torque value, https://www.fastenal.com/content/fed...for%20A574.pdf.
