Old 12-26-2012, 07:23 PM
tjducet tjducet is offline
Mein Auto: 2006 BMW 750Li
Post iDrive glitches
Hi Bimmerfest;
The iDrive on my 06' 750Li seems to have started doing the "funky chicken". If I try and access any menu options that are to the lower half of the main menu the selector switch knobs jums around in the menu options uncontrolably. I was thinking of fully disconnecting the battery and doing a "cold Re-boot" so to speak. anhy advice will be appreciated.
tjducet
Old 12-28-2012, 08:33 AM
RichmondF RichmondF is offline
Mein Auto: 2002 BMW 745i
I have an 02, and I know that the iDrive itself has changed since then. However, one thing may remain the same...
Check your glove box and feel around on the ceiling of the glove box (from the inside). There should be a plastic door which swings down and inside there should be a "ring fuse" (black plastic O ring connected to a junction with cords leading from it). Turn off your vehicle and pull the ring fuse, wait a minute or so, and put the fuse back in. This restarts the iDrive. Then start your car and see if it works. If it does not work, pull the ring fuse again while the car is on/running and leave the ring fuse pulled then see if it works without the fuse. Mine had this issue just yesterday and curiously worked if I pulled the ring fuse and left it pulled.
As far as pulling the battery goes, Im not sure if it is the same on the 06, but if you pull the battery on my 02 then you have to re-register the battery to the computer when you connect it again. Check your battery voltage, my iDrive issues were solved by replacing the battery.
Old 02-08-2013, 02:15 AM
Hi Rich;
I found the o-ring you mentioned unfortunately I can't seem to get it out. Is there any trick? I don't wan't to reef on it and risk breaking it or similar. Any advice?
Thanks.
tjducet
Old 02-08-2013, 09:37 AM
cbell13055 cbell13055 is offline
Mein Auto: 05 CTS-V
Hey not to thread hijack, but
Do you have the sport wheels powder coated black? I've been thinking about doing this, and was wondering what it would look like.
Could you send me some more pictures cbell13055@gmail.com
2008 Jet Black 750i. Sport, Luxury Seating, and Logic 7. <3
