The X5 SAV Forum
Old 12-27-2012, 12:21 AM
krisc222 krisc222 is offline
Mein Auto: x5
Red face No turbo boost
Hi everybody!
Can anyone help with this one please?-
X5 3.0 diesel not boosting turbo,therefore bo power up hills,turbo working but only boosts once or twice then car is a slug!!any ideas would be appreciated! Thanks!!!
Old 12-27-2012, 08:42 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Turbo BMW's are still rare over here so I do not think many will be able to assist. You could try xoutpost or one of the UK based BMW boards. From my limited knowledge of turbos I can only suggest a stuck open waste-gate valve as your problem.
GL.
Old 01-03-2013, 03:28 AM
Macka Macka is offline
Mein Auto: X5 2006
I had a similar problem which turned out to be a broken nipple on the vacuum accumulator tank for the turbo. It is the small plastic tank on the drivers side in the engine bay with a hose connection at each end. There was absolutely no acceleration up to 2500rpm.
I used SuperGlue as a temporary fix. Hope this is your problem as it was an easy repair.
Good luck.
Old 01-05-2013, 06:00 AM
Mein Auto: x5
Thanks will look at that tomorrow!
