E34 (1989 - 1995)
Old 12-27-2012, 09:49 AM
S406 S406 is offline
Mein Auto: 00 S4, 93 525i
Bad gas mileage at ilde?
On my 93 525, I wasnt positive on which way the cluster needle for the gas mileage is suppose to go. But it seems as though I get horrible mileage at idle. It goes to the 0 side instead of the 40 side. Is this correct? im averaging between 15.9 and 17.4mpg with almost all hiway. The exhaust has an odd smell sometimes like I have never smelled before. Not coolant, rotten eggy or a rich smell. Its smells chemically kinda. Ive been working on cars for 20+ years and have never smelled anything like it.
The valve from the brake booster to the intake has a nipple on the underside that is broken and sucks air into itself. Is it suppose to be plugged or is it suppose to take air into it? Is there a hose that is laying out of site that has broken off of it?
Old 12-27-2012, 10:16 AM
r33p04s's Avatar
r33p04s r33p04s is offline
Mein Auto: E36/4/5
Miles per gallon...if you're not moving at idle it will be 0, coasting at idle it will go the other way...come on now
I believe rotten eggs mean a dead cat
Maybe someone can help with the booster...probably should have a line connected
Old 12-27-2012, 10:21 AM
lol Thats what I kinda figured. But my audi is the opposite and a 325ix Im working on goes to the 40mpg side at idle. Not a rotten egg smell...
Old 12-27-2012, 06:14 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
If the car is not moving, you are getting 0 mpg. The gauge is working correctly
First thing I would do is repair the vacuum leak at the booster. Then before I condemed the cat convertor I would be looking at an O2 sensor. Before that I would be looking at tune up items like plugs, wires, injectors.
Your milage seems a little low for an M50 525. Could be a lot of things, heavy foot, auto trans, even a small amount of stop and go mixed in, or what you city folk consider highway driving sometimes
My 535/5 averages about 24, mostly highway, but I run it hard too, everytime it goes out.
We really need a whole lot more info to be much help.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 12-27-2012, 07:10 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
If it smells like a fire-cracker...that's the combination of nitric oxide and nitrogen dioxide (NOx). It's from running near or too lean. Any significant vacuum leaks or deficient fuel delivery would definitely be suspect.
Good food, good people, good times.
Old 12-27-2012, 07:48 PM
Banned
Mein Auto: car
Have you tried pulling the error codes via the stomp test ?
Old 12-28-2012, 07:57 AM
BMWFatherFigure's Avatar
Old School
Does the broken part pull air all the time? If so fix it.
Current:
E38 Parts Car
Previous:
Old 01-03-2013, 12:36 PM
fryntyr fryntyr is offline
Mein Auto: 1991 BMW 525I
If you do the O2 sensor, spend the $15-$20 and go ahead and swap out the Coolant Temperature sensor as well. The CTS is what was causing mine to cough at idle (sometimes die) and have worse gas mileage. I was back up to 25-26 hiway on my 91 525 before it got wrecked last night with the CTS change. In prior weeks I fixed many vacuum leaks and cleaned the ICV which helped but didn't cure it.
