E90/E91/E92/E93 (2006 - 2013)
Old 12-27-2012, 05:54 PM
06 325i 06 325i is offline
Mein Auto: 325i
325i engine swap
hello i was wondering if someone could give me some advice, I have a 2006 325i, and wanted to swap the engine for somthing else, i was looking at the 06-07 335i engine, does anyone know if this will fit, and if not what would be a good engine to swap it with.
Old 12-27-2012, 09:17 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
anything other than the stock engine will be very expensive to retrofit. forget the twin turbo N54.
even the engine out of a 330i will be difficult. you would need to find some way to reprogram the car to be able to control the new engine. it is not just a drop in replacement.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 12-28-2012, 09:47 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You can change it into 330 without changing engine.
You can change it into 330 without changing engine.(might be worth it)
In other country's they make supercharger kits but its not worth it.
What can be done
http://www.eurotuner.com/techarticle...25i/index.html
http://www.e90post.com/forums/forumdisplay.php?f=35
Engines are very expensive like airplane engines on these.
Think 15k for a new engine installed so if you mess with it you are really gambling a lot.
Old 12-28-2012, 11:36 AM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Random question: is there EVER a time where an engine swap makes sense for E90s?
Every time I've seen this question, the answer has been one of these:
No, because swaps are hella expensive. It's cheaper to sell your car and buy another one with the engine you want.
No, because it's cheaper to tune the engine to get the numbers you want.
BMW CCA Member
