Old 02-03-2013, 10:38 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by shawnsheridan View Post
Ok. I have PM'd you the link. Good luck!
Mine calculates to 0:
Name:	VIN CheckDigit.png
I checked other VIN's and it changes.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 02-03-2013, 06:36 PM
hamfei hamfei is offline
Mein Auto: 2012 E90 CLI
What VIN value did you change to in the EEPROM? Empty means FF not 00...
Old 02-07-2013, 12:36 AM
seems mate is not here...
Old 02-07-2013, 03:32 AM
mateforrest mateforrest is offline
Mein Auto: BMW F16 3.0D & mini F54
Yes i did it to FF
I´m very busy with my work , but your procedure doesn´t works.
Next post
Regards
Old 02-07-2013, 05:37 AM
Originally Posted by mateforrest View Post
Yes i did it to FF
Next post
Regards
Which procedure does not work? The Tool32 KOMBI01.prg?
Old 02-07-2013, 06:31 AM
Old 02-07-2013, 06:37 AM
I can't find the commands hamfei said.
Hamfei, could you help me please?
Old 02-08-2013, 07:10 AM
Any idea please?
Old 02-09-2013, 12:23 PM
djsaad1 djsaad1 is offline
Mein Auto: range rover
Shawn Thanks million for all your help.
This is the proof of vin erased:
Attachment 360512
No CAFD.
And this problem:
com.bmw.esys.domain.psdz.PsdzException: Failed to get CAFs for SWE "swfl_000003c1-004_054_006". [C111]
at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2088)
at com.bmw.esys.domain.svt.SvtLogic.getCAFsForSWE(Svt Logic.java:395)
at com.bmw.esys.gui.svt.SvtCompareController.callActi onGetCafsForSWE(SvtCompareController.java:695)
at com.bmw.esys.gui.svt.SvtTargetView$ActionGetCAFFor SWE.doActionPerformed(SvtTargetView.java:549)
at com.bmw.esys.gui.AbstractView$AbstractGuiProgressA ction$1.init(AbstractView.java:389)
at com.bmw.esys.gui.component.DialogProgress$2.constr uct(DialogProgress.java:136)
at com.bmw.esys.gui.component.SwingWorker$2.run(Swing Worker.java:145)
at java.lang.Thread.run(Unknown Source)
Caused by: KIS error: Die technische Einheit 000003C1 konnte in der KIS-Wissensbasis nicht gefunden werden.
Timestamp: Thu Jan 31 23:32:05 CET 2013
SessionId: default
ErrorCategory: SYSTEM_ERROR ID: 1283
Class: com.bmw.psdz.uc.LogicImpl
ExecutionContext={category=KIS, ecuid=(UNKNOWN,?)}
at com.bmw.psdz.uc.LogicImpl.getCAFsForSWE(LogicImpl. java:1173)
at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2085)
... 7 more
Attachment 360513
Attachment 360514
Please friends, any advice?
I am getting this same error with a different file when trying to install a new 6wb from 6wa.
Old 02-09-2013, 01:57 PM
Any idea please?
bimmertech is going to code my new 6wb. It seems like it doesn't have a vin and I am getting the same error you are getting. I will watch what they do and let you know. Hopefully they will be able to do it in the next couple days.
Old 02-09-2013, 02:18 PM
It must be due to KOMBI not having the car's VIN. I have just replied to your PM.
Old 02-10-2013, 10:24 AM
Thanks, plese tell me the solution when you know.
Old 02-10-2013, 04:11 PM
With KOMBI01.prg, jobs cps_lesen and kombi_uhrzeit_datum_stellen, what do you show for VIN and Mileage?
cps_lesen (VIN):
kombi_uhrzeit_datum_stellen (Mileage):
The Mileage is in KM, so the 39899 km in my case is 24792 miles (km x 0.621371 = miles)
Old 02-11-2013, 11:52 AM
Shawn i Will check, it's so laborious swap the speedometer.
Old 02-11-2013, 12:07 PM
Really? The Video makes it out to be simple. 2 Fasteners and a connector plug...
Old 02-11-2013, 12:14 PM
I am not sure about the 5 series, but on the 6 series you have that huge arc above it. http://www.cartype.com/pics/9492/ful...cluster_13.jpg
It's not hard to unlatch it but maneuvering it out and in without scratching anything is pretty hard.
Bimmertech coded mine, but after getting the ip from zgw search it seems like he was able to vpn straight to the car with his computer through edibias tool. I didn't get to see anything.
Old 02-11-2013, 12:18 PM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
Damn the luck...
Old 02-16-2013, 07:47 AM
Originally Posted by snj1013 View Post
Damn the luck...
Hello do you have more information?
Old 02-16-2013, 10:00 AM
What psdzdata are you running? When I updated mine to 48.3 it found the missing swfl files for the 6wb so now I can detect cafd from swe while before I wasn't able to. Is it possible you are using old psdzdata that doesn't have all the swfls for the 6wa?
Old 02-16-2013, 10:13 AM
Hello I using 47.5, but i not sure if i can use 48.3, what about token code?
Shawn any help?
regards
Old 02-16-2013, 10:15 AM
cps_lesen (VIN):
Attachment 361728
Attachment 361729
I sent you an email
Regards
Old 02-16-2013, 10:19 AM
You mean 6WA, not 6WB?
Well, it is good that Detect CAF for SWE is now working, although it is hard to understand why with 48.3 PSdZData it is suddenly working considering 6WA has been around since 0311 when 46.1 was out.
Old 02-16-2013, 10:21 AM
I think the same.
Old 02-16-2013, 10:23 AM
Shawn any help?
regards
You can use 48.3 for F10, no problem. The Patch / Token issue is only for the 48.3 F20 PSdZData.
I sent you an email
Regards
Got it.
Old 02-16-2013, 10:24 AM
No it started working for 6wb, my car came with 6wa. Even after bimmertech coded my car I still couldn't detect cafd on 48.1. But once I updated to 48.3 it detected the cafd from swe.
Is it possible he needs to be at 48.1 to get those swfls he is missing?
